First post, by diqits
Guys i have problem to install some Games. Cause lot of then have a installatione where they need 2 Disks or more to put in. The problem is my PC hasn't a floppy drive and so i must mount them what is not hard but, i have the problem that i can't mount the 2nd device (2nd floppy disk) in dosbox cause it's already mounted.
SO How can i switch the floppy disk directory when it's mounted on the same letter.
Hope you guys know this
    5.37 KiB
The best BeatmUp is One must Fall
Reply 1 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
From the Readme:
IMGMOUNT A utility to mount disk images and CD-ROM images in DOSBox. IMGMOUNT DRIVE [imagefile] -t [image_type] -fs [imag […]
IMGMOUNT
IMGMOUNT DRIVE [imagefile] -t [image_type] -fs [image_format]
-size [sectorsbytesize, sectorsperhead, heads, cylinders]
imagefile
Location of the image files to mount in DOSBox. The location can
be on a mounted drive inside DOSBox, or on your real disk. It is
possible to mount CD-ROM images (ISOs or CUE/BIN) as well, if you
need CD swapping capabilities specify all images in succession.
The CDs can be swapped with CTRL-F4 at any time.
Even though it only mentions CDs, it is also true for Floppyimages. Something to remember for the next version of Dosbox to correct in the readme, I think.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 5, by diqits
that was not the problem i have 2 disk directory and i can only mount 1 on every letter. But the thing is that the installation can't switch to the other letter, but for the program there is one floppy and not more. How can i continue my installation.
I dont' use cue or bin Files.
i use
mount a "C:\Duke2\Disk1" -t floppy -ioctl
mount b "C:\Duke2\Disk2" -t floppy -ioctl
mount c "D:\Duke Nukem 2"
Reply 3 of 5, by MiniMax
Rank Moderator
Moderator
As Dominus pointed out, use imgmount:
1) Create images of the diskettes.
2) Mount the 2 diskettes as
imgmount A C:\path\to\image1.img C:\path\to\image2.img -t floppy
3) Swap between the 2 images with CTRL-F4.
DOSBox 0.73 ReadMe | DOSBox Wiki | DOSBox 60 seconds guide | How to ask questions
_________________
Lenovo M58p | Core 2 Quad Q8400 @ 2.66 GHz | Radeon R7 240 | LG HL-DT-ST DVDRAM GH40N | Win 10 Pro
Reply 4 of 5, by ErikGG
Another way to do it :
Mount one directory as a floppy.
Then when the installer asks for Disk 2 erase the mounted "floppy" directory in Windows Explorer
Copy in all files from disk 2 with Windows Explorer.
Then press CTRL-F4.
Continue with installer.
This should work too as I recall.
Erik.
Read the new FAQ.doc
