First post, by IkeFox
I've tested this board below with different components, but all it does is a long, high-pitched beep (~2 sec. with a 2 sec pause, repeated indefinitely) when turned on.
According to several beep code lists for the Award BIOS, this indicates a RAM issue. Retroweb says this board takes FPM RAM: https://theretroweb.com/motherboards/s/asus-p-i-p55tp4
I tried 2 x 4 MB FPM modules (single-sided), 4 x 4 MB FPM (single-sided), 2 x 16 MB EDO (single-sided) and 2 x 32 MB EDO (double-sided), all with the same result.
Other components I used for testing are a Pentium-S 75 MHz, 2 PCI and 1 ISA graphics cards, and multiple ATX PSUs (with an adapter cable). All components have been tested and work fine with other boards.
FSB clock and clock multiplier have been double- and triple-checked (Note: the picture shows settings before configuring it for the Pentium-S 75). I also checked the only manual I could find, which is not exactly for this model but seems close enough (P55TP4XEG V2.1 and V2.4): https://www.manualslib.com/manual/434035/Asus … P-I-P55tp4.html The jumpers are in different locations but are numbered the same and the settings match the ones printed on the board.
Core voltage is set to 3.3 V from what I gathered from the manual. There are also jumpers for cache RAM voltage. Not sure what the difference between mixed voltage or 3.3 V cache RAM is, but I left the jumpers as they were, since I got the board with cache preinstalled.
I haven't tried changing the cache yet, but I'd be surprised if the BIOS can even detect an issue with cache RAM. Does anyone have an idea what else could be the problem, or is the board just broken?
Reply 1 of 6, by jakethompson1
Nice board; can you imagine having such a high end system in 1995, pre-Windows 95?
Check the back of the board behind the SIMM slots for any traces that may e scratched through. It would always looks to the system as if there is no RAM even when there is.
Although the BIOS would be agnostic to cache at this stage, it is possible if one of the cache chips is bad it is holding an address or data line high or low like a short circuit.
I have had both of these happen in the real world.
Reply 2 of 6, by TheMobRules
In my experience ASUS boards of this era that use Dallas RTC exhibit a really strange behavior when the battery is almost depleted, sometimes not POSTing at all. As soon as I desolder it and do the CR2032 mod they usually start working properly.
Also, not long ago I got a P55TP4XE which had a couple of leaking and totally out of spec capacitors near the cache, but this may be anecdotal evidence.
Reply 3 of 6, by BitWrangler
The "I'm too cheap or in too much of a hurry to buy a battery holder" dallas mod goes like, perform trepanning as per normal, saw the top off a 500ml waterbottle with the neck the same size as a CR2032, push a drawing pin (thumbtack) through the cap, solder your black wire to that, then strip the end of the red wire, wrap it around the end of the neck you sawed off, and screw the cap down trapping the strands against the + side of the CR2032 and the - side against the drawing pin. Then solder ends into exposed contacts in Dallas.
Edit: the I can't find a water bottle or IPA/peroxide bottle version goes, get a sprung clothespeg/clothespin, push thumbtacks through opposite sides of jaws, solder to ends of those, clamp cr 2032 between them, wrap metal bits with tape so they don't rattle onto anything they shouldn't.
Then the, "no no, you really don't understand how cheap I am and I don't have a clothespin or thumbtacks." version goes, snap a popsicle stick in half, strip 2" off the end of your wires, wind it round the end of each bit of popsicle stick several times and twist the end back to the wire, at the other end, wrap an elastic band around it multiple times, clamp cr2032 between, insulate with tape, peeled off sticky label, whatever. Expect the elastic band to perish and fail in a few months though. Possibly the popsicle stick will have enough spring to bind it with thread or something.
Reply 4 of 6, by IkeFox
Thank you all for the input. The traces and capacitors look fine. Swapping the cache did nothing. I also tried powering on the board with no RAM installed and got the same beep code.
Guess the dead battery might be the problem, I've read about other boards too that won't boot when the battery is empty.
I'd rather not do any soldering myself and leave it to someone else to mod it. It does look like a nice board but in the Pentium class the GA-586AX is my favorite right now.
Reply 5 of 6, by jakethompson1
Don't know where you are physically located but I'd take it to a VCF event or VCF repair workshop if one is nearby
Reply 6 of 6, by IkeFox
jakethompson1 wrote on 2024-03-08, 21:55:
That's also a good option, but since I don't plan to keep it anyways I'll let the new owner decide what to do with it.
