Reply 640 of 3464, by RaVeN-05
1) Stability/No lockups - ok
2) Corruption - after execution , no corruption
3) Red Square appearing on screen, no, corruption here i think
4) 60 Hz on exit, yes capture card can capture it.
odd thing windows can't start it tells problem with videocard it restarts to safe mode, than i can restart to normal.
https://fex.net/s/czkobnz
on fex 3 videos, of vga capture and one from phone
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 644 of 3464, by sharangad
Thanks.
One more:
https://1drv.ms/u/s!As-dKk-N73dSmDOuYbmvEkulMKTj?e=STDJ9Y
MD5: 4869ac0c70584dc406ef4cfcd2d978e2
This has the mystery mouse call INT 33h that Nascar fails on. It also has tweaks to the rendering. You won't see anything on screen, because the output display buffer is almost certainly wrong.
https://www.youtube.com/@sharangadayananda\
https://patreon.com/Rready
Reply 647 of 3464, by sharangad
Something funky happens to dosbox's mouse handler after running SPeedy calls.
That Int 33h mouse call isn't know on your system. It just returns the same parameters that it started it.
But with Nascar it calls it with the duff values and the mouse handler fails. I think I need to a Speedy3D Int 33h call which redirects mouse commands from the RReady window to dosbox, scaling the coordinates to fit Speedy3D 's(640x480).
Reply 648 of 3464, by BEEN_Nath_58
Wanted to say this thread is going at the speed of a bullet 💀
Reply 651 of 3464, by sharangad
Does anyone know what the two parameters passed to RenUtil are?
RenUtil a b
produces:
INT 10h with AX = 0x158B, BX = a
INT 10h with AX = 0x158C, BX = a
INT 10h with AX = 0x1585, BX = b
INT 10h with AX = 0x1586, BX = b
Reply 654 of 3464, by Agent of the BSoD
Yep, I discovered the txt file for it earlier. My post about it is here (same thing RaVeN-05 linked) and what I observed with it in the post below.
Re: Rendition Verite Thread
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 655 of 3464, by sharangad
@Agent of the BSOD:
1) Can I have a copy of your V1000 BIOS, I just realised I don't have an image of it. Your (Rendition) ROM BIOS offset is 0x9FC, but I no longer appear to have a copy of it. The reason I ask is I'm trying to avoid loading a BIOS file into RAM and maintaining just a minimal image, but I don't have your BIOS.
2) Is RenUtil actually a TSR or does it just flip some switches in the BIOS?
Reply 656 of 3464, by Agent of the BSoD
Here's a dump of mine. Also, renutil is not a TSR.
Reply 658 of 3464, by sharangad
V1000/V2000 Microcode disassembler (Incomplete,):
https://1drv.ms/u/s!As-dKk-N73dSmDXYLf6oCXyrcZzL?e=cJNqWR
MD5: edc9bbaae092c1ce4c1c47e8f1678c52
The endianness might be wrong for the instructions, I can't really tell. Also some instruction opcode names are dumped without correctly listing params.
I'm not sure I'll even need this. I'm also not sure the ELF header's being dealt with correctly. Some files, like VOH, have duff ELF headers. Not sure whether they're even ELF files.
To decode:
RenDecode <filenam>
Source:
https://1drv.ms/u/s!As-dKk-N73dSmDa-3h_bPHrH_xYX?e=Bsn4Bm
MD5: 2dcd2c888aadc7255e5d0fa5dba13a6e
The instruction endianness might have to be swapped, not sure. To enable that decomment this line:
Line 465 in RenditionUCode:
//if(bigEndian)
//instruction = _byteswap_ulong(instruction);
Reply 659 of 3464, by sharangad
Capping the load of the Rendition BIOS to 32KB fixed the mouse bug with Nascar. Now it just goes into a loop waiting for a Sound Blaster interrupt, without issuing any Rendition commands.
