Is there a good utility for modern windows (10 preferably) that can be used with a USB compact flash drive to determine the geometry (sectors, heads and cylinders) of a CF card?
I have tried using biosdrvs and ideinfo on my vintage 386 system (using a cf->ide adapter attached to the i/o card) but I can only get that to work if I first enter the correct geometry info in CMOS setup, creating something of a catch-22 for me.
For now, I have to unpack and set up my XT system and run biosdrvs with the CF card attached to the XT-CF Lite card to find out the correct info. It would be way more convenient to determine it on my modern system.
Don't know of a utility that can do it off the top of my head, but it would need to use an ATA passthrough command to wrap an ATA identify request (which would return the cylinders/heads/sectors values reported by the card)... and the USB adapter would need to actually know how to handle the passthrough command instead of just returning an error (most do but not all).
Victoria (hdd.by) probably?
There's a port of hdparm but never tried it (as in: support the original not the imitation 😜)
And yup, you'd need an USB-IDE converter that supports UAS or the leading proprietary passthrough methods - which I suspect you won't find in any modern-ish multi card reader nor in a golden age of CF one…
I'm not sure what a passthrough is, I'm afraid. What I am using for CF reader is [this device]
USB-to-storage adapters don't always let the host send any command it wants to the target device, because that's more work, so they just support the basic read/write/etc. stuff. Commands required for SMART are an example of something that often won't work with USB adapters - the documentation for smartmontools describes all the hoops you sometimes have to jump through to tell it how to use some device-specific way to pass through the ATA commands via the USB adapter to the device - and the ATA "IDENTIFY" command that you can use to get a device's geometry probably have similar issues, I would imagine. I assume that part of the issue is that the standard for USB mass storage devices would have standard commands defined for reading and writing, but probably not for getting C/H/S 😁
I think CF readers are much less likely to support those sorts of commands, and my Lexar one certainly doesn't. I got a "professional" one in the hope that it would, but I guess people like photographers probably don't care much about drive geometry or checking SMART monitoring!
USB-to-ATA adapters like this tend to be more of a power user thing, so I think they're more likely to support those commands.
I think the one I linked is the one I have (at least it's the same brand), and when I use that with a passive adapter that lets me attach a CF card to a 44-pin ATA + power connector, I can use the Linux hdparm command, which shows the geometry:
1$ lsscsi 2[...] 3[6:0:0:0] disk CF Card /dev/sdd 4$ sudo hdparm -I /dev/sdd 5 6/dev/sdd: 7 8CompactFlash ATA device 9 Model Number: CF Card 10 Serial Number: 13[................] 11 Firmware Revision: Ver6.04L 12Standards: 13 Supported: 5 4 14 Likely used: 6 15Configuration: 16 Logical max current 17 cylinders 3872 3872 18 heads 16 16 19 sectors/track 63 63 20 -- 21 CHS current addressable sectors: 3902976 22 LBA user addressable sectors: 3902976 23 LBA48 user addressable sectors: 3902976 24 Logical/Physical Sector size: 512 bytes 25 device size with M = 1024*1024: 1905 MBytes 26 device size with M = 1000*1000: 1998 MBytes (1 GB) 27 cache/buffer size = 1 KBytes (type=DualPort) 28 Nominal Media Rotation Rate: Solid State Device 29Capabilities: 30 LBA, IORDY(cannot be disabled) 31 Standby timer values: spec'd by Standard, no device specific minimum 32 R/W multiple sector transfer: Max = 1 Current = 1 33 DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6 34 Cycle time: min=120ns recommended=120ns 35 PIO: pio0 pio1 pio2 pio3 pio4 36 Cycle time: no flow control=120ns IORDY flow control=120ns 37Commands/features: 38 Enabled Supported: 39 SMART feature set 40 Security Mode feature set 41 Power Management feature set 42 Write cache 43 * WRITE_BUFFER command 44 * READ_BUFFER command 45 * NOP cmd 46 * CFA feature set 47 * 48-bit Address feature set 48 * Mandatory FLUSH_CACHE 49 CFA max advanced io_udma cycle time: 80ns 50 CFA max advanced mem_udma cycle time: 80ns 51 * CFA advanced modes: pio5 pio6 mdma3 mdma4 io_udma4 io_udma5 io_udma6 io_udma7 io_udma8 io_udma9 *io_udma10 mem_udma4 mem_udma5 mem_udma6 mem_udma7 mem_udma8 mem_udma9 *mem_udma10 52 * CFA Power Level 1 (max 750mA) 53Security: 54 Master password revision code = 65534 55 supported 56 not enabled 57 not locked 58 not frozen 59 not expired: security count 60 supported: enhanced erase
…Show last 3 lines
61 60min for SECURITY ERASE UNIT. 60min for ENHANCED SECURITY ERASE UNIT. 62Checksum: correct
As already mentioned, there's a port of hdparm to Windows, but I can't vouch for it either.
OP said they were hoping to use their modern system. I assume that since IDEINFO is from 1991 or so, it might be a challenge.
I know that you can generally boot DOS from a USB device (maybe some firmware is making this difficult now though?) but I assume the BIOS just installs an interrupt 13h handler allowing access to the drive, rather than emulating an IDE/ATA controller, so that might be an issue?
I guess sometimes the onboard SATA controller can be configured to operate in a legacy mode, will it appear as an IDE/ATA controller then? If so maybe using a SATA-to-ATA adapter would help, so long as that adapter passes through the necessary commands. I imagine it should pass through the IDENTIFY command at least since that's how the BIOS figures out the disk capacity, and not passing it through would break disk auto-detection?
Then I wonder if one could make this more convenient by using eSATA?
The thing that I would find less convenient about this setup is the need to supply power to the ATA-to-CF adapter, and possibly the SATA-to-ATA adapter. Using a 44-pin adapter like I suggested above means everything is powered by USB.
dosheawrote on 2024-03-23, 10:14:OP said they were hoping to use their modern system. I assume that since IDEINFO is from 1991 or so, it might be a challenge. […] Show full quote
I have USB-IDE converter/adapter almost identical to the one mentioned by @doshea and can fully confirm that it provides the geometry of the CF card under Linux with command:
