Voodoo banshee problem
First post, by rain
Hi, ive some issue with game : dreams to reality.
Im using. Diamond banshee agp, installing game with instalfx version. But when starting game its closed opening screen , and return to desktop. 3dfx splash screen appering then Nothing..
i ve heard voodoo2 or voodoo 1 files needed this game but cant figured how to do this.
_retired retro pc user_
Reply 1 of 5, by Shagittarius
Well I can tell you the reason you are getting that error message is because you are running with a Voodoo2 Glide2x.ovl file. You need to use one for the Banshee. However, I have tried this in pure DOS and I end up frozen on a black screen. This could be because I dont have the right version of the .ovl, or that I have too much RAM on the system (64MB) but I can confirm I get the same message as you when using the .ovl for a voodoo2. You can try a banshee ovl or a voodoo3 ovl, and maybe you will get lucky with version compatibility.
Making progress, going to limit that RAM on the system:
The attachment Dreams_shot1.jpg is no longer available
Well I can't get it to load after selecting to start a new game. Im going to drop the Voodoo 3 .ovl file here, extract it and copy it into you game directory and run it, see if you can get any further. This should at least get you past the error message.
The attachment glide2x_Voodoo3_V1.03.04.rar is no longer available
Reply 2 of 5, by rain
Shagittarius wrote on 2024-03-14, 04:51:
Well I can tell you the reason you are getting that error message is because you are running with a Voodoo2 Glide2x.ovl file. Y […]
Not working with your glide ovl file , where can i find banshee ovl file?
BTW ive 1gb ram installed on system
Reply 3 of 5, by Shadzilla
rain wrote on 2024-03-14, 08:07:
That's waaaaaaaaaaay too much ram for what looks like a Windows 9x system.
If you can find the original drivers for the card that should include an appropriate glide2x.ovl, or drivers for another Banshee. I've attached the one that ships with my Creative 3D Blaster Banshee you can try.
Reply 4 of 5, by rain
glide error not appearing any more but game not runing as always.
Reply 5 of 5, by Shagittarius
This game is a product of its time and is very fussy. Your only hope is to keep trying different drivers with an appropriately configured period correct machine. Otherwise just play the software mode unfortunately.
