Ripper w/DOSbox
First post, by vonpookie
Following the directions in the DOSbox game info isn't working for me:
Copy INSTALL folder from CD1 to HDD. Apply 1.03 patch. Apply 1.05 patch. Run SETUPV.BAT. Run RIPPER.EXE /v /v3.
I've copied the Install folder from the CD img to the desired folder, and installed both patches with no problems.
However, when I go into DOSbox and run SETUPV.BAT it starts, but then stops with an error of "Error opening file setuptxt.tf"
There doesn't seem to be anything wrong with that file--I can open it in Notepad and see the text in it, and it is not marked as read-only or archived.
Any ideas?
Reply 1 of 2, by vonpookie
Nevermind--I got it running. I was looking through the list of files in the folder again and noticed one called "installv.bat". Tried that one on a lark and had a pleasant surprise when it started right up to the installation screen. Game seems to be running just fine.
Thanks anyway!
Reply 2 of 2, by eL_PuSHeR
[Moved]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
