Reply 740 of 1544, by robertmo3
windows 98se behaves differently than win11
win98se changes irqs according to bios changes.
so they are the same in dos and win98se
unless of course they are not assigned in bios, than win98se assigns them of course.
Reply 741 of 1544, by sharangad
My testing probably fried your hard drive. I don't think that's why the Rom bios dump failed.
If you could try @agentbsod's fix for f1. He says with the F1 drivers redline and verite in the F1 folder and v10003d.uc in windows/system F1 runs without the F1 wrapper. He also says you need verite. Vxd in the system folder. I believe the V2000 ref drivers already have that as an active driver.
Just give it a go. If it works there's yet another way to play F1 on V2000.
Need to be careful with your hardware. They don't make Verité boards anymore.
I remember one of those F1 wrapper tests took 6 hours.
Or you could relax 😀
https://www.youtube.com/@sharangadayananda
Reply 742 of 1544, by sharangad
Is regular rebel moon on rredline or cgl?
It was in your video of Rendition games.
Reply 743 of 1544, by RaVeN-05
Rebel Moon on Verite, speedy 3d, looks better than on rising engine.
Its just my very old hard drive.
All ok
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 744 of 1544, by sharangad
Well I'm glad you got that sorted. I'll get you a fresh build tomorrow. There's something I need to test.
I don't know if I can call real mode software interrupts from dos32a. I found a link once which said it could through int31h. But I can't find any it anymore. Will persevere.I need protected mode to perform pokes into high address ranges.
[EDIT] Figured it out how to real mode calls from 32 bit protected mode.[/EDIT}
Reply 745 of 1544, by sharangad
[EDIT] This is wrong. Ignore this. The ROM address has to be read through a BIOS call.
@Raven-05, here you go.
https://1drv.ms/u/s!As-dKk-N73dSmFFY1-qOeFqc8C_p?e=2AcR6E
MD5: 205896b3551b5f2276d4148d62737f02
Let's try dumping the BIOS again. Edit the run.bat file if you need to see console output. I've redirected it to a file. The ROM should be dumped again.
150th time lucky maybe.
This is a 32 bit app. Hope it works.
You can run it with run.bat. If you want to do it manually dos4gw fifo.
Reply 746 of 1544, by sharangad
Fixed (h0pefull);
https://1drv.ms/u/s!As-dKk-N73dSmFIu_YsW43foCyda?e=Dyq71q
MD5: 8912f54a2a531fde5443c2fb7d2d3e6e
This should query the ROM extension address and dump it.
[EDIT] Same instructions as before [/EDIT]
Reply 747 of 1544, by RaVeN-05
Rendition Segment 0000C000, Rendition Base 00000A2C
Rendition ROM Address is 00000000
Detected V2000 board
Membase : DE000000
Portbase : D000
RAM : 4194304
640x480/16 Mode Num is 0, granularity is 0 KB
Error mode not found
001
Membase : DE000000
Portbase : D000
RAM : 4194304
Tested Formula1 with latest release, works ok, everything great.
Older FIFO's still produce 0xff or 0x00 filled files
Reply 748 of 1544, by sharangad
Thanks. That real mode int 10h call from protected mode isn't working. I'll try and fix it. It gave me a lot of grief with dosbox but eventually managed to get it to work.
It's not working on real hardware.
Reply 749 of 1544, by RaVeN-05
i think you know pcem or 86box is a low level pc emulator where you can run dos as on real machine?
also i recall this https://github.com/86Box/86Box/discussions/1933 )
Reply 750 of 1544, by sharangad
This won't work, but I need the output from it to see what's up:
https://1drv.ms/u/s!As-dKk-N73dSmFN4PsVdnAfo9QBz?e=TabOVe
MD5: a82a6dbbb9ec2c4b5a949d6515943fb9
Reply 751 of 1544, by sharangad
RaVeN-05 wrote on 2024-03-17, 12:06:
I am aware of pcem/86box. I have an installation on my machine with W98 at the moment. One of the guy(s?) working on it planned on adding Rendition emulation.
The BIOS address space for a ROM is 32 KB C000:000 C000:7FFF. The Rendition docs claims it has a 128 KB BIOS. It also says it's mapped into high address ranges.
But doesn't say which address range. There's a PCI register marked ROM extension, which is what I'm trying to read, but it's coming out as all 0s. By ROM extension do they mean an add on extra ROM or the built in ROM?
Reply 752 of 1544, by sharangad
If we succeed at Speedy3D maybe the PCem/86Box team will get free Rendition support running native drivers. (y)
Reply 755 of 1544, by sharangad
Bit beat. Need to get some sleep. WIll probably get back to it sometime tomorow.
You have plenty of time to run fifogw3 before then.😀
Reply 757 of 1544, by RaVeN-05
verite has texture filtering and colored lightning, other graphics effects)
!no matter! i like verite more , period dot dot !DOT!
______________________________________________________
no comments anymore.
__________________
i really tired and live in war.
Keep good mood here, there is not right topic to discuss best ever rebel moon version!
@sharangad under windows its creates fifo.txt , under dos its hangups after standard messages of dos4gw.
ROM port 00
ROM port 00
ROM port 00
ROM port 00
Successfuly read VESA block
Signature:"VESA"
Version:200
OEM name:"9Qt
f9AuìÀtèZ[Ã"
Capabilties:0002
RAM: 4096 (KB) (4.000000 MB)
oemVersion: 00
Vendor:"Null"
Product:"Null"
Revision:"Null"
Accelerator Caps: 00
Supported VESA & OEM modes :023f:c00046f5
Supported VESA (Accelerated) modes :023f:00000000
F9E,C9,465,70,16,60B,465,70,465,70,FF54,F000,8008,F000,E7FF,F000,00,D000,28,60B,EF6F,F000,EF6F,F000,EF6F,F000,EF6F,F000,9A,60B,465,70,07,D070,F84D,F000,F841,F000,24D7,FD64,E739,F000,7273,10BC,42D,70,A28,375,E7A4,F000,2F,6CC,FE6E,F000,1168,10BC,1D,D000,F0A4,F000,522,00,58B2,C000,FA8,C9,445,7B8,314,A15,1188,10BC,118C,10BC,FBC,C9,FC6,C9,FD0,C9,106C,C9,466,70,5B4,375,106C,C9,106C,C9,106C,C9,162,A15,1CC,A16,E4EA,C90F,E700,F000,106C,C9,01,896,106C,C9,106C,C9,106C,C9,106C,C9,106C,C9,106C,C9,106C,C9,106C,C9,106C,C9,106C,C9,106C,C9,106C,C9,EC59,F000,EFD5,F000,F065,F000,5CB2,C000,E7FF,F000,E7FF,F000,EFE5,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,2637,FD4E,E7FF,F000,E7FF,F000,E7FF,F000,4FC,70,EF6F,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,0D,8A3,E7FF,F000,E7FF,F000,E7FF,F000,00,00,00,00,00,00,00,00,00,00,00,00,00,00,40,897,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,E7FF,F000,5DE,C000,E7FF,F000,E7FF,F000,35,60B,ECF3,F000,EF6F,F000,EF6F,F000,E2,60B,F0FC,F000,FA,60B,112,60B,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,22,2EB7,FCC6,202,
Membase : DE000000
Portbase : D000
RAM : 4194304
Reply 758 of 1544, by sharangad
OK. I see the problem. Let me see if I can fix it.
BTW you've done a lot pushing for Rendition support. Let's hope we can get Speedy3d running soon.
Dos allocated pointers don't seem to be accessible in protected mode.
