First post, by Socket3
Hey everyone. I've been working on yet another super socket 7 build for the last couple of weeks, with the goal of reproducing the computer I had as a teen, but, since I'm not having any luck sourcing a working VIA MVP4 motherboard, I settled for an MVP3 + a dedicated Trident Blade 3D. After putting it all together, I realized how slow the whole thing is, much slower then I remember. So I started experimenting with different components. The 400MHz K6-II was replaced with a 550MHz K6-II+, and I started testing different budget video cards, looking for that sweet spot - slow, but usable.
I'd like to share the data I collected while testing the PC with all of you, it might be useful.
Test system:
AMD K6-2+ 550MHz
128MB ram
AZZA 5VMD VIA MVP3, AT Form factor
Creative Vibra 16 ISA
Roland SCC-1
300W FSP ATX PSU
late 90's AT case with modded power button (for use with the aforementioned ATX PSU)
Win98SE, DirectX 7
The video cards:
HIS Trident Blade 3D 90MHz/90MHz, driver version 4.12.01.2229
SiS 305 16MB AGP, (CS305, Unidentified) drv 1.15:
RIVA TNT 16MB AGP (1290A, Unidentified), forceware 6.31:
RIVA TNT2 M64 32MB AGP, (Powercolor SNiper M) forceware 6.31:
Geforce 2 MX400 64MB SDRAM 128bit 200/150Mhz (Sparkle), forceware 6.31:
S3 Savage 4 16MB (Fastware AG460D) AGP, 110/121MHz, driver 4.12.01.8226:
3DFX Voodoo 2 12MB (HIS Arcade), driver 30100:
placeholder - forgot to take a pic
Benchmarks:
- GL Quake 1.19 640x480 16 bit color, demo1.dm2, sound enabled
- Quake 2 3.20 640x480 default opengl (3dfx opengl for the voodoo card), 8 bit textures enabled, timedemo demo1, sound enabled
- Expendable - 640x480, default settings, built in benchmark - glide renderer used for Voodoo 2
- Homeworld - 640x480, 16 bit color, Direct3D renderer (glide render for Voodoo 2), framerate logged with Fraps, 2 minute battle scene between roughly 50 ships from a skirmish game
- 3DMark 1999 - 800x600 default settings
Results:
Quake 1 – 47.8 fps
Quake 2 – 31.6 FPS – feels smooth (*S)
Homeworld – 41 fps *S
Expandable – 23.31 fps
3DMark99 – 2905 pts
Trident Blade3D 8MB AGP (HIS) drv 4.12.01.2229
Quake 1 – 36.6 fps
Quake 2 – 23.7 fps
Homeworld – 31 fps
Expandable – 20.51 fps
3DMark99 – 1868 pts
Quake 1 – 54.8 fps
Quake 2 – 46.3 fps
Homeworld – 37 fps choppy (*C)
Expandable – 29.61 fps
3DMark99 – 2980 pts
Quake 1 – 122.4 fps
Quake 2 – 75.8 fps
Homeworld – 41 fps *c
Expandable – 32.13 fps
3DMark99 – 2923
Quake 1 – 59.7 fps
Quake 2 – 51.7 fps
Homeworld – 35 fps
Expandable – 32.89
3DMark99 – 2158 pts
Reply 1 of 35, by douglar
Those are some outrageous Quake scores for the Geforce 2MX. Does the driver support 3dnow or something?
Reply 2 of 35, by Socket3
douglar wrote on 2024-03-17, 21:23:
I was suprised as well, but chucked it up to the motherboard being a great performer (witch it is). However, I'm not fond of running nvidia cards on super 7 PCs. Sure, the max FPS is fantastic, but there is stuttering in some games. Homeworld for example - whenever zooming in on one ship the game stutters. When zooming out in large fleet battles, more stuttering. In Half Life, again, stuttering, but with the Savage 4 or a Kyro there is no stuttering whatsoever.
I don't really know, but it's the driver version I've been using with super 7 builds for years. If it does, I'd be great if someone more knoladgeble could confirm it.
Reply 3 of 35, by Joseph_Joestar
If you haven't already done so, try the 3DNow! patch for Quake 2.
It should improve the scores a bit further, especially for the Voodoo 2.
My retro builds
Reply 4 of 35, by Socket3
Joseph_Joestar wrote on 2024-03-17, 21:30:
I don't have the 3DNow version on this machine, but it would probably be a good idea to get it, since I've narrowed the video card choice to either the SiS 305 (low avarage FPS but very smooth) or maybe the S3 Savage 4, and every little bit of extra performance helps. I plan to test a PowerVR Kyro (1) and a Radeon DDR on the platform as well, then make a final choice. I might even expand the benchmark series to include the Riva 128ZX, the Kyro I, afformentioned Radeon DDR, the Rage 128 PRO and a Voodoo 3 3000.
Reply 5 of 35, by Joseph_Joestar
IIRC, the 3DNow! patch will offer a slight boost to any card, but it's particularly effective on a Voodoo 2.
I tried it on a Voodoo 1 and a Voodoo 3, and the performance did improve, but the difference wasn't quite stellar. The 3DNow! + 3DFX renderer which uses 3dfxglam.dll is custom tailored to the K6-2 paired with a Voodoo 2, and should provide significant gains on that setup.
My retro builds
Reply 6 of 35, by Garrett W
The reason Quake is so much faster on GeForce is the HW T&L, which Quake can make use of and is particularly impressive on a slow CPU such as the K6 series.
Reply 7 of 35, by rasz_pl
Garrett W wrote on 2024-03-18, 00:54:
GLQuake? I was under the impression all the math is done by quake code, miniGL receives precalculated triangles and there is nothing for TnL to do.
Reply 8 of 35, by Garrett W
No miniGL on GeForce. GLQuake is using OpenGL for which GeForce provides a full ICD. The extensions expose this feature!
Reply 9 of 35, by leileilol
I'd sooner think it's about texture memory. Note the T&L-less Savage4 also beats the V2 at both by a good margin. The margin would be even larger on some thrashy maps (like q3dm11 the best map to make a v2 sli elitist cry on). Q3 benchmarking usually takes place on Q3DM6 which is the fastest running map in the game for being enclosed and not having much texture variety or portals.
GLQuake can still give a Voodoo2 a hard time over dynamic lightmap updates causing little upload hitches.
Reply 10 of 35, by BitWrangler
The thing that's actually surprising me about the MX400 is that it hasn't got the same lead in everything else that it's got in the quakes. Then also I get the impression in other reviews that a Savage 4 can't actually stick it's neck out ahead of a TNT2 M64, but here it is, not a particularly fast example is it? That is taking a convincing lead over it in most things.
Reply 11 of 35, by Socket3
BitWrangler wrote on 2024-03-18, 03:26:
It's your garden variety Savage 4 (Fastware AG460D) running at 110/121MHz. I have higher clocked versions of this card. I think it's taking a lead over most things because it's driver has less CPU overhead then say the nvidia cards. On a faster machine the GF2 MX should outperform it consistently.
I'm tempted to repeat the tests on a 2600+ Thoroughbread (2083MHz) / KT333.
Reply 12 of 35, by Ozzuneoj
Socket3 wrote on 2024-03-18, 06:19:
I would like to see that! I was really surprised by the numbers you got with the Savage 4. I have done a fair amount of tinkering with cards of this level on my Pentium III 850Mhz 440BX test rig and while the Savage 4 was certainly among the best cards that wasn't from 3dfx or Nvidia, it never seemed to be as good as any Voodoo or TNT cards I've run. That could all just be my perception though... I haven't done formal testing exactly.
What driver versions were you using for the TNT, M64 and Voodoo 2?
Also, nice job! These numbers are very handy for people looking to put together a suitable retro PC.
... thinking on it now though, it would be cool if there was a way to use modern benchmarking tools and techniques on retro PCs. Over the past 15 years or so a lot of benchmarking sites (starting with TechReport) have started focusing more on frame times and consistency, which can paint a very different picture of smoothness and responsiveness compared to an average FPS number. I would be curious to know where cards from this era stack up in that regard (I feel like 3dfx cards in Glide would shine there), but I don't think the tools exist to measure frametimes on such old hardware\software. Actually, much more recently some reviewers (like Gamers Nexus, with the help of software being developed by Intel) are breaking benchmarking down even further to see where exactly during the pipeline the bottleneck is so that you can actually see and chart the impact of driver overhead and CPU speed on GPU render times... really amazing stuff that would have fundamentally changed the development of GPUs, drivers and APIs if it had been available 20 years ago.
... but I digress. FPS numbers are probably fine when we're dealing with frame rates mostly under 40. 😁
Reply 13 of 35, by Joseph_Joestar
Ozzuneoj wrote on 2024-03-18, 06:34:
Yeah, average FPS numbers don't always tell the complete story. For example, in Quake 3, I get 120+ FPS on a GeForce FX 5900XT at 1600x1200 using the timedemo benchmark. And yet, during actual gameplay, the FPS tanks whenever I approach a portal or a mirror, like the ones in Q3DM0 (the very first tutorial map).
Best you can do, without specialized tools, is to measure the lowest, average and highest FPS in games which allow that. For example, Unreal and UT99 can do this using their built-in benchmarks. If your lowest FPS score is above 60 while benchmarking, you can be reasonably sure that you're in for a smooth ride during actual gameplay.
My retro builds
Reply 14 of 35, by Ozzuneoj
Joseph_Joestar wrote on 2024-03-18, 06:52:
Yeah, generally if minimums are at a tolerable level it will be okay. The issue really comes in those situations where performance is fluctuating a lot per second... for example, frames taking 33ms half the time and the other half taking 8ms, you'll feel pretty nasty stutters (like 120 to 30 fps) even though the frame rate would likely be recorded as 60fps by most software.
It's funny we have the luxury of even thinking about such things now. Someone trying to game on a Trident Blade3D was just happy to be able to play a game with hardware acceleration at 25fps back in the day. And if you had bags of money laying around you could get some crazy Quantum3D SLI monstrosity to hit 6ofps at 1024x768 in some games... and two years later it was worthless for any kind of 3D gaming, and your CPU was probably less than half the speed of whatever the latest thing was. 🤣
Things were so much more "interesting" back then...
Reply 15 of 35, by MikeSG
It's an AGP 2x motherboard.
WIth AGP 4x, the TNT2-M64 should be +40% faster, and the Geforce 2 MX-400 should be +200-400% faster.
Reply 16 of 35, by asdf53
Thanks a lot for these interesting benchmarks. I love that you only tested budget cards, to me SS7 is a budget platform so using these feels very appropriate. I wouldn't have thought that the Savage4 performs so well and even beats a GF2 MX, especially at these low clock rates. It's also very overclockable, I remember clocking mine to around 150/160 and it didn't even get particularly hot.
The Kyro also performs very well on SS7 systems, I got 3700 points in 3dmark99 with a Kyro 2 (3380 with a GF2 MX). The Geforce also needs old drivers to perform well, some newer games are unplayable with those. The Kyro performs well across the board using the newest drivers, even in OpenGL. I think it was the best performing SS7 card out of all that I tested.
If you feel that your MVP3 board is slow, may I suggest trying these tweaks: https://www.k6plus.com/phpBB3/viewtopic.php?t=1406
On my system, this improved 3DMark99 scores on a Geforce 2MX from 3000 to 3400 points, so it's well worth the effort.
Reply 17 of 35, by Socket3
Driver versions, sistem specs and software used are posted in the first thread, as well as where I listed the benchmark results in text format.
Nvidia drivers (in general) don't play nice with some VIA chipsets, particularly the VP3 and MVP3, witch has a negative effect on perfromance. I used a rather early driver, forceware 6.31, witch I've had great results with in the past. This driver seems to be the most tolerant of the MVP3 chipset - however, I believe the low numbers obtained with nvidia cards are due to said driver's high CPU overhead when compared to cards from other manufacturers. I believe I can prove this by benchmarking on a much faster platform, that will eliminate the CPU bottleneck.
As for frame-times, the SiS and S3 were significantly smoother, despite the low FPS. I wish I could see 1% lows in old games, since I believe the stuttering I experienced on nvidia cards is due to a wide gap between 1% lows and maximum FPS, leading to overall "jerkiness". This is most notable with the Geforce 2 MX in Half Life, but it's quite apparent in Homeworld.
Ozzuneoj wrote on 2024-03-18, 07:01:
I remember that feeling - when I got my K6-II in 1999? and fired up quake 2 and I remember it ran pretty decent, even well at 512x460. I completed a lot of 3d accelerated games on that machine. Quake 2, Heretic 2, Blood 2, Homeworld, Kingpin, Dungeon Keeper 1 and 2, Dark Reign 2 and so many others - that little on-board Blade 3D ran like a champ. Looking at the specs for my test card (90MHz core / 90MHz ram) it's easy to see why. Despite having shared memory, the on-board version of the Blade 3D is slightly higer clocked, with memory running at 100MHz, despite being shared, and core running at 110MHz according to documentation. That might explain why my old K6 felt faster - that or the nostalgia of FINALLY being able to play all those demo CD's I'd saved up 😁 I guess if I really want to re-create the experience, I really need to find an MVP4 that runs, or a Trident Blade 3D turbo witch is quite a bit higher clocked (135Mhz(ish) for both core and memory depending on model)
asdf53 wrote on 2024-03-18, 09:54:
Thanks a lot for these interesting benchmarks. I love that you only tested budget cards, to me SS7 is a budget platform so using […]
Thank you, and thanks for the link - I'll try some of them on my AX59 Pro. I don't want to mess with this particullar board, as I am quite happy with it's performance.
Reply 18 of 35, by rasz_pl
any visual glitches on sis/s3/trident?
Garrett W wrote on 2024-03-18, 02:10:
afaik no full OpenGL support in GLQuake in the first place, and it doesnt matter if driver offers extension when GLQuake was created in 1997 and doesnt use it.
Looked into the code instead of guessing, GLQuake does indeed use glTranslatef(); glRotatef(); glScalef(); so OpenGL driver can TnL those.
MikeSG wrote on 2024-03-18, 09:16:
Haha, no! Not even on faster CPUs. You are looking at couple percent at max. Look at platforms memory bandwidth to get a perception of scale, even x2 is too fast for K6.
Reply 19 of 35, by Socket3
rasz_pl wrote on 2024-03-18, 12:53:
any visual glitches on sis/s3/trident? […]
Nope. All games tested looked great, with the mention that the Blade3D doesn't do Bump Mapping - but that's a minor detail considering the games it's contemporary with. Output quality on the Trident and Savage 4 is excelent. The SiS 305 on the other hand was over-bright - kind of washed out, like you see on some cheap PCI cards from the mid 90's. Looks fine on a CRT tough. Another mention is that all nvidia cards were very dark under openGL, and no fiddling with the brightness or gamma sliders fixed that. The Savage was pretty dark under openGL as well. The voodoo 2 was too bright in quake 2.
