First post, by OpenRift
Like the title says. Honestly, I really don't even know what could be causing this issue, because it only seems to happen consistently with Ultimate Doom v1.9 where sound just stops after about a minute, and like once in Doom II 1.9 (tho that may just be less consistent). Quitting and re-launching Doom, the sound was back, but only to last for around the same amount of time as before. Testing Tyrian 2000 resulted in only the FM music playing from the card. Quake seemed to work just fine, though. There's probably other games that have similar issues, but here's the weird thing:
This only happens when running in DOS mode, I've encountered none of these issues while running these games in Windows 98SE.
I've tried numerous different configurations of my DOS mode's autoexec.bat, and nothing seems to work. I also tried switching from generic SB16 drivers to specifically these Vibra16 drivers from the vogons library, still no change.
Sure, I could just stick to running the stuff in Windows, but I'd like to have both modes fully working.
So with that said, does anyone know what might be causing this issue? Is there another specific driver I should be running instead?
