Reply 52200 of 58514, by PcBytes
Scored today:
- P5Q Pro
- GB Radeon 9000
- Medion GF4 MX460
- Thermaltake case w/ P5B SE, P4 631, 4GB DDR2 (a bit strange for a 631 to have that much RAM), XFX 8500GT 256M, 2x160GB WD Caviar SE PATA
- ASUS GF 6600 (non-GT unfortunately) AGP
- Dell 2407WFP monitor - hella massive!
Reply 52201 of 58514, by PC@LIVE
PcBytes wrote on 2024-03-17, 22:04:
Scored today: […]
Scored today:
- P5Q Pro
- GB Radeon 9000
- Medion GF4 MX460
Coincidentally, just a few minutes ago, I posted on my page, something about the ASUS P5Q PRO, I just have a slightly misaligned pin, maybe there's no need to fix it, but I'll see what I can do, as a CPU, initially I should use a Core2 Duo E4600, which I had mounted on the Linux PC, and which I later changed with an E4700 2.60@3.00GHz, we will see if the card starts without problems, later I will change the CPU with a C2Q E8300 at 2.5 GHz, which I could certainly more overclock a little.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
Reply 52202 of 58514, by BitWrangler
The quads are a bit more sensitive to missing ground and power pins than duos, so tweak as many as you can straight.
Reply 52203 of 58514, by InTheStudy
"Untested".
But as it turns out like - actually.
http://inthe.study/stuff/boudoir.m4v
After I got it home (this was testing at my work, where we have a box of abandoned PSU's - holding a headphone against my crackberry) I hooked it up to the World's Worst Recording Studio, ran Rosegarden on one monitor and Ardour on the other; and recorded a couple proper tests.
https://inthe.study/stuff/force.mp3
https://inthe.study/stuff/cosmo.mp3
So yeah - that works, and works perfectlt. No battery leakage, or any damage at all - but I do need to email the guy at our partner org I send hardware repairs to, and ask him to replace the very dead battery with a holder before it DOES leak. Does anyone know the right part to drop in to an MU50's battery pads, to hold a CR232?
Reply 52204 of 58514, by PC@LIVE
BitWrangler wrote on 2024-03-17, 23:28:
Thank you very much friend, there is only one slightly crooked pin, it's a minimal thing, it could make contact or not, I'll try to fix it anyway, I hope that pin is not essential, and therefore if the contact isn't perfect, it still works .
However, for those who want to take a look, you can find the images on my page, here on Vogons:
Re: Test and troubleshoot PC@LIVE motherboards
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 52205 of 58514, by InTheStudy
MIDI Mountain, you fill me with sweet musical goodness!
The attachment midihill.jpg is no longer available
Reply 52206 of 58514, by H3nrik V!
Since it's originally specified for LGA775 and LGA1366, I call "retro" on the Cooler Master V10 "hybrid air cooler". It came, however with a bracket, that also finely fits the LGA115x of my daily driver i7-9700 ... Might wanna slap it on there ...
It's a 10 heat pipe aircooler, except 4 of the heat pipes are attached to a TEC module, which is controlled to avoid condensation etc., giving extra cooling performance. (well according to reviews back then it's something like 0.5-1.5 degree C 🤣 ) I bought it for being an abomination of over-engineering. Loving it!
Reply 52207 of 58514, by H3nrik V!
H3nrik V! wrote on 2024-03-19, 13:38:
[Edit] Should've put a banana for scale, as its sheer size doesn't really show ... But to give an idea - the visible fan is a 120 mm one 😁 [/edit]
Reply 52208 of 58514, by BitWrangler
Wow, that's utterly ridiculous... I want one 🤣 ... I kinda feel like it would put me on a quest to find a C2Q that would run at 5ghz though 🤣
Reply 52209 of 58514, by Nexxen
When a hobby becomes a murderous environmental hazard!
Hope you put on kevlar safety shoes when handling it 😀
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 52210 of 58514, by H3nrik V!
Nexxen wrote on 2024-03-19, 14:20:
I'm actually kind of surprised, how light 1.2 kg feels 🤣
Reply 52211 of 58514, by nuno14272
New material
1| 386DX40
2| P200mmx, Voodoo 1
3| PIII-450, Voodoo 3 3000
Reply 52212 of 58514, by PC@LIVE
I ordered this CPU today, it is a P4 2600 400, socket 478, I plan to use it in a MB ASUS P4B266, which I will repair soon, later I will see if it is possible to make it run at almost 3 GHz, without overvolts, I already have a P4 2800 400 478, on a PC with SDRAM, but this could go a little faster, because the P4B266 uses DDR, in the meantime I'm waiting for it to arrive, I have time to change the capacitors, and test the card.
AMD 386SX-33 4MB
P60 48MB
iDX4-100 32MB
Reply 52213 of 58514, by ubiq
Hmm...
Reply 52214 of 58514, by andrea
ubiq wrote on 2024-03-19, 19:44:
Hmm...
I remember reading somewhere that the Apollo 693A/596B are supposed to be pin compatible with the 440BX (or ZX, same thing really)/PIIX4, so that vendors could use the same design for both solutions changing only the bios.
Reply 52215 of 58514, by Big Pink
Hmm...
It's definitely not a sticker? 😁
I've noticed QDI P3 boards always have a sticker covering up the VIA southbridge, presumably in an effort to hide the chipset from the discerning but not too discerning customer of the day.
I thought IBM was born with the world
Reply 52216 of 58514, by Nexxen
Reply 52217 of 58514, by weedeewee
Hmm...
theretroweb will be interested in photos & bios for that via board.
https://theretroweb.com/motherboards/s/acorp-6via85p
duh.
Do not ask Why !
Reply 52218 of 58514, by BitWrangler
This one also may be around in Via and Intel versions... https://theretroweb.com/motherboards/s/ford-lian-bx-6vp2
Reply 52219 of 58514, by AppleSauce
I dunno if this counts since a mate of mine gave it to me. But since he had an Australian pair of Roland MA20s he wanted to declutter so he gave me his spare pair of japanese voltage rated roland MA20s.
The attachment 20240320_114849.jpg is no longer available
