First post, by AlessandroB
To my incredible surprise, by mounting the adapter you see in the photo without connecting it to the power supply, it works perfectly! I didn't think it would take power from the normal 40-pin IDE cable, but is this something expected? Doesn't it overload the IDE controller circuitry?
Reply 1 of 13, by kingcake
CF cards can receive power on pin 20.
Reply 2 of 13, by AlessandroB
kingcake wrote on 2024-03-19, 08:39:
Pin 20 is marked as “missin pin” that means factory can connect it to +5v or not? and why? to feed what?
Reply 3 of 13, by stanwebber
i'd like to know on what chipsets this power on pin 20 is prevalent on.
Reply 4 of 13, by Yrouel
AlessandroB wrote on 2024-03-19, 08:16:
Beware that if you're not getting power explicitly on pin 20 it means the card is working essentially through unintended paths and/or leakage and that might very well lead to data corruption and even loss of the cf card.
I had this happen to me when I plugged an adapter to a controller card and forgot to power it explicitly and it borked the cf card.
If you want things to be neater either add power to pin 20 (if it's physically on the motherboard connector) or you can bring 5V from any other header on the board like for example USB or IRdA, you just need a single female-female dupont cable (ground is already well connected)
Reply 5 of 13, by douglar
stanwebber wrote on 2024-03-19, 12:34:
Most modern XTide cards have this as an option.
Reply 6 of 13, by AlessandroB
Yrouel wrote on 2024-03-19, 12:46:
Beware that if you're not getting power explicitly on pin 20 it means the card is working essentially through unintended paths a […]
if the card wont take power from pin20... wich one can provide? all the other are data cable...
anyway, if i measure 5v on my pin20 i can be sure that my adapter take power from it in a correct way?
Reply 7 of 13, by douglar
AlessandroB wrote on 2024-03-19, 19:47:
If you see 5v on pin 20, you are probably OK. What IDE controller are you using?
Reply 8 of 13, by AlessandroB
douglar wrote on 2024-03-19, 19:56:
is the one integrated in th IBM pc330 486DX2
Reply 9 of 13, by weedeewee
for all the people saying pin 20...
pin 20, the keypin, the pin that seems to be missing on OP's photo. That pin is delivering power ?
Truly we live in amazing times.
Do not ask Why !
Reply 10 of 13, by darry
EDIT: sorry wrong link. I can't find where I wrote that I saw that with a CF card on a Startech IDE to CF adapter. Or maybe I never wrote about it and imagined that I had .
EDIT2: Found Using a vintage multi-track recorder as a mixer, namely the Roland VS-880EX - might apply to other Roland VS- units , but that is not what I remember either. I think I was using the 40-pin input on the CF adapter and am not sure anymore whether I checked pin 2o.
I had a similar surprise with a mysteriously powered CF card . No pin20 either .
Re: What is the current carrying capacity of a wire in 40-pin IDE (ATA) and 44-pin IDE (ATA) cables ?
Reply 12 of 13, by douglar
weedeewee wrote on 2024-03-19, 21:05:
I didn’t even think to look at the CF adaptor. Good eye!
Reply 13 of 13, by kingcake
Right I should have clarified. I was making a statement of fact. Didn't mean to imply that's what was happening in OP's case.
