First post, by Themanwho
Hello,
Do you know where i can buy the bios chip witch is missing on this S3 Virge DX ?
Thanks
    378.01 KiB
    591.64 KiB
Reply 1 of 5, by dominusprog
https://www.ebay.com/itm/274470204543?epid=21 … ABk9SR5bi0c3LYw
https://www.ebay.com/itm/113591300496?itmmeta … %3ABFBMluLRzctj
Reply 2 of 5, by CoffeeOne
Themanwho wrote on 2024-03-20, 15:47:
Hello,
Thanks
Do you have access to a EEPROM/flash programmer?
If no, it does not make sense to buy a chip, just buy a working S3 Virge DX, will be cheaper most likely.
Reply 3 of 5, by analog_programmer
dominusprog wrote on 2024-03-20, 17:14:
SST27SF256 28-pin flash EEPROM is better alternative than these UV-erasable EPROMs. I bought two of these recently (one to change OTP ROM for S3 ViRGE 325 videocard and one for XTIDE boot ROM in 3Com NIC) from the well known chinese "fleabay". There's also 512 kbit (64 kB) version - SST27SF512, but S3 ViRGE 325/DX/GX BIOSes are 32 kB in size.
from СМ630 to Ryzen gen. 3
engineer's five pennies: this world goes south since everything's run by financiers and economists
this isn't voice chat, yet some people, overusing online communications, "talk" and "hear voices"
Reply 4 of 5, by dominusprog
analog_programmer wrote on 2024-03-21, 10:02:
Well, if the person has the skills, he/she can use a larger EEPROM.
Reply 5 of 5, by analog_programmer
dominusprog wrote on 2024-03-21, 15:04:
Of course, he/she can. I'm just pointing that it's easier to use EEPROM chip instead of EPROM - needs only programmer, not UV-light eraser + programmer.
