First post, by boby
I have a Compaq Deskpro EN, P3 1Ghz, 512 MB RAM, with integrated intel 815 gpu + Nvidia GeForce MX 4000. Windows 98SE.
Without this card, everything works fine, but when I insert it I get this Windows Protection Error. Restart your computer.
I saw similar posts like this, but all of them are if you have > 512 MB of RAM. I have exactly 512 MB one module.
- Memtest is ok
- Tried latest nvidia drivers + one older downloaded from vogons
- Tried unofficial SP3 for Win98
- Tried setting those two parameters (forgot the name) in system.ini
What else can I try?
P.S. System + all drivers were installed first and then I put this nvidia card and installed drivers for it
Reply 1 of 3, by Gustl
How many MB RAM does the graphics card have?
Reply 3 of 3, by boby
Update:
At the moment version of the driver 77.12 worked on fresh windows install. I will install other drivers now to check if that will cause any problems
Update 2:
Intel chipset driver cause the error to show up. So probably conflict with integrated gpu drivers?
