CoffeeOne wrote on 2024-03-21, 18:10:
The ISSI61C1024 5volts 32pin dip, existed in 3 variants 12ns, 15ns and 20ns. So 10ns is 100% re-labelled.
CoffeeOne, you could be absolutely right, I am affraid....
Next tests with the SYL8886-board are done.
1. L2-CACHE
The highest FSB for the recognition of L2 is 40 MHz (at least for the modules I have)!
At FSB 50+60, no L2 is present (apart from one case with 128 KB - but this was not stable in Windows), even with slowest cache-timings of 3-2-3 in BIOS, and regardless of the modules and if it‘s 512 KB or 256 KB.
At this time, no chance for success, but I will test some other modules as soon as I can.
In case of no recognition of L2, there is always the message „Write Back Caching Accelerated“ on the 2-nd POST-page. If L2 is present (at FSB 40), this message is replaced by „XYZ KB L2 Cache Enabled“
2. RADEON-VGA
Yes, a Radeon 9250 can work with this board, too. This is the only Radeon-VGA I have at this time for testing.
Catalyst 4.3, 4.7, 5.2, and Omega 2.6.29 could be installed.
With Catalyst 4.3 and 5.2, more than one loop in Quake I are possible.
With Catalyst 4.7 and Omega 2.6.29, there is a full freeze of the 3D-picture in Quake I at the first or second loop. Sometimes in 2D the picture disappears complete (black screen). Reducing the LDEV# Sampling Point from1 to 2 in BIOS does not help.
The pictures attached are from Catalyst 5.2
The FPS in Quake I and Quake II are for all drivers more or less very similar (+/- 0,2 FPS, a little better with Omega): Quake I: 15,7 FPS, Quake II: 10,8 FPS.
So the performance is much lower compared to the Geforce 2 MX-400 from above.
All test are done without L2-cache (empty sockets), but there is no difference to the Geforce-tests above (because they are done with inactive L2-cache, too).
Maybe I will try Windows 2000 (to be honest I do not like it for a retro-system) the next days, if I found some time.
Just for reference – are they some other 486-systems running a R9250, and are they any Quake-results?
