First post, by transitionality
After finding out that certain DoxBox builds now have zip mounting support, I got ahold of ykhwong's and gulikoza's builds, and then started looking for a frontend that supports zip mounting as well. So far, I've downloaded DBGL. However, I'm stuck. I can't get DBGL to mount zips. I click Add Profile, define the game's name, then go to mounting options, choose the zip mount, add the game zip, and create and add a blank zip file for savegames, then click OK. The config line at the top indicates that the game zip gets mounted as C using PhysFS. So far so good. But I have no idea how to fill in the Execute -> DOS -> Main and Execute -> DOS -> Setup sections. Whatever I put in there causes some sort of error and the game refuses to work. Please help, or recommend another frontend that supports zip mounting in DosBox. Thanks.
