First post, by oh2ftu
I purchased (quite affordably, actually) a 486-motherboard.
It is an MSI MS-4118, but the manual at the retroweb is not quite correct.
If you have a look at the manual you will see that it's different from the uploaded pic (seems to be a similar board to mine).
Just a few differences:
- JP1 not present or is located elsewhere
- No viable documentation for J1 (manual states 3-pin, it's 5pin on the board). Also located right next to the keyboard connector - PS2 mouse2?
- Bios-chips is elsewhere situated -> the lowest ISA-slot is 8bit, not 16bit.
-> is someone able to de-link MS-4118 ver2 from the Frontier industrial ISA486GSi?
Anyone happen to have the correct manual? MS-4118 ver:2.
I will take a bios dump when I can verify that it's in full working order.
