First post, by Jackhead
- Oldbie
Im really happy found this solution to use my Mega Drive Controller on my old DOS PC.
But i got a problem on some part. First at all i leave the potis as is and jumpered the Dip switches 1 and 4 to on.
So i have second fire button and 5v on pin 5 as the MD use.
Tested some Games like keen4 and harry anything works fine.
Than i try to run Rusty Dos Version and here my down button has no function. All the other button works fine.
To compare the issue with a gravis gamepad down works just fine.
I wonder if this is maybe a calib problem?
What dos software can i use to calib X/Y Axis with this adapter?
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
