First post, by RetroGameplayer
I'm trying to run a bank of 4x 24GB Tesla GPUs on this motherboard as a Blender rendering rig and find no GPU over 6GB works. I don't see any resizable bar options in the BIOS.
I was also hoping to use ECC DDR3 RAM with this motherboard as I've plenty of it, but again it doesn't seem to be supported. I know this isn't exactly vintage hardware here, but thought I'd ask if anyone has experienced modding BIOS to get around such problems?
Many thanks!
Reply 2 of 2, by RetroGameplayer
Roman555 wrote on 2024-03-30, 17:43:
Maybe you will be able to add Re-Bar into the BIOS by yourself if you make use of some tutorials. As example: https://github.com […]
As example:
https://github.com/xCuri0/ReBarUEFI
https://youtu.be/vcJDWMpxpjE?si=t7cIOasdVFzXkKtc
Thank you so much, this is great to start with!
