DOS games with native DB50XG/SW60XG support
Reply 20 of 35, by Demolition-Man
A bit ot: Is there a list of games where the Yamaha MIDI option (General MIDI) is intended as the optimal requirement. I have a version of Super Street Fighter 2 with MIDI option. I know the original very well from the Super Nintendo. I tested all the options available to me. FM sound 8bit and 16bit. Then AWE32 and MIDI from the Dreamblaster S2. It sounds most authentic with the DB50XG. Unfortunately I don't have the Roland option (like the X2GS SE). So what do you think: Was Roland seen as the standard for the normal General MIDI back then, or were there games where the normal General MIDI was optimized for Yamaha, albeit without additional XG options.
Reply 21 of 35, by Joseph_Joestar
Demolition-Man wrote on 2024-03-31, 09:00:
Many western developers used a Roland SC-55 for composing game music during the early-mid 90s, so it sounds the best when played back on that device. Japanese developers usually favored Yamaha's products (whether OPM, OPN, OPL or XG) so their games often sound best on those.
The MT-32 page on the Vogons Wiki has a column titled "original synth" which denotes what device the game music was originally composed on. It's useful for reference purposes
My retro stuff
Reply 22 of 35, by Demolition-Man
Ok this makes sense, thx!
Reply 23 of 35, by M-HT
megatron-uk wrote on 2024-03-30, 08:28:
The sound configuration utility for Albion, which uses the Miles sound system, has a discrete option for choosing the DB50 for music:
I don't know if this is actual XG music, or 'just' GM mapped to the DB50/DB60/XR385, as my XR385 board is currently packed away. I can't remember ever testing it to see if it was any better/different to the GM/Sound Canvas option.
Albion has only one set of music files and uses the same music driver for DB50-XG and for General MIDI, so it doesn't have any special support for XG.
Reply 24 of 35, by Demolition-Man
Are other instruments perhaps used in the XG setting or tuned differently without using the additional XG options? Or does it not work that way? The XG MIDI stuff is still new to me, but I'm happy to learn.
Reply 25 of 35, by RetroGamer4Ever
Demolition-Man wrote on 2024-04-01, 09:22:
To answer your question, GM is covered under XG, so there is no difference in sound between a GM and XG MIDI - when played on XG hardware - unless the MIDI data is formatted or tweaked to use XG commands and to take advantage of XG MIDI's additional instruments, features, and capabilities, which can vary wildly from hardware to software and hardware to hardware. To make it more confusing, there are two different kinds of XG (Regular XG and Sondious -XG), three tiers of XG hardware/software synths with different instruments and performance capabilities, and backwards/downward compatibility of XG MIDI data between various XG hardware and software synths is not always there, but forward/upward compatibility is pretty much guaranteed, so you can take an XG MIDI file that was made on an older/lesser XG synth and have it sound great on the newer/higher-end synths, though you can't always do that with a MIDI file done on the newer/higher synths because the instruments/sounds used can be different. For games, what I said means mostly nothing, as the few games that used XG were almost entirely composed with the S-YXG50 (soft-synth) or DB50XG/DB51XG (MIDI daughterboard) and MU50/MU10 (hardware), which is basic XG and not the more advanced, with bells and whistles. In today's world, you can get by and meet your needs by using the S-YXG50 VST and FalcoSoft's VST Host MIDI Driver and MIDI Player and completely forget about XG hardware, unless you are looking to run a vintage hardware setup and require correct hardware or you are running a newer/current PC (The last Yamaha XG modules are compatible with current systems) or you just need the advanced musical functions and capabilities of the last XG hardware for whatever reason.
Reply 26 of 35, by Joseph_Joestar
RetroGamer4Ever wrote on 2024-04-01, 11:46:
If using old hardware, another option is to get a Yamaha YMF7x4 card. Those are XG compatible and sound great in games which support it, such as FF7. The driver panel even has a Sondius-XG checkbox.
file.php?id=106643
There's an XG capable music player on the driver CD, along with sample music files. I made some recordings of the sample tracks here and also of some FF7 music here.
My retro stuff
Reply 27 of 35, by RetroGamer4Ever
Is that included player the XG MIDI player that I keep seeing in people's YouTube vids? If so, I always wondered where that came from. I've been mostly using FSMP for my XG playback, but the S-YXG50 player is (surprisingly) fully functional with the S-YXG50 VST - albeit completely basic and simple - on current Windows systems.
Reply 28 of 35, by Joseph_Joestar
RetroGamer4Ever wrote on 2024-04-01, 14:01:
It's called Ystation and I think I got it from this driver CD along with the sample XG music files.
It's been a few years since I made those recordings, so I'm not entirely sure whether it was that exact CD image. My YMF744 card is currently sitting in storage so I can't double check at this time.
My retro stuff
Reply 29 of 35, by Demolition-Man
I know it's a bit OT again, and I apologize for that. I think my DB50XG, which was broken, still doesn't work properly. Difficult to reproduce, but occasional hanging notes occur. Is this a known bug? And no, it has nothing to do with the Creative hanging note bug that Daughterboard runs on an AZT 2320 card. I read something about a reset command. How do you send it and when is it used? Before or after a certain game, or a certain running time? Sorry again for my beginner questions.
Reply 30 of 35, by fillosaurus
Joseph_Joestar wrote on 2024-03-30, 17:05:
Demolition-Man wrote on 2024-03-30, 15:12:
Yeah the setting are working, but not the game. I dont have luck with these early Win95 games.
Have you applied patch 1.02 after installing FF7?
Also, the game doesn't like it if the system has more than 512 MB RAM, even after applying R. Loew's PATCHMEM. I had to manually limit the available RAM to 512 MB using MSCONFIG to get FF7 to run on my Athlon64 rig,
AFAIR I played FF7 on my Athlon X2 4200+ with 2 Gb RAM. And a Yamaha 754 soundcard. Never had any RAM problems, and played it with a dual USB/PS gamepad, with PS buttons layout.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
Reply 31 of 35, by Joseph_Joestar
fillosaurus wrote on 2024-04-04, 05:22:
This is the error that I would get on my Athlon64 system:
file.php?id=151313
The nonsense about the swap file was weird, because I didn't disable it, and there's of course plenty of space on the C: drive. Anyway, the problem went away after limiting the RAM to 512 MB, and came back if I undid the limitation. For whatever reason, that was the cause on my system.
My retro stuff
Reply 32 of 35, by RetroGamer4Ever
Demolition-Man wrote on 2024-04-01, 23:25:
The card needs to be tested with an external wavetable interface board, like the Serdaco CHILL board adapter. Only then, will you truly know if it's still broken, which it might be. At this point, it's becoming less likely to get used daughterboards that aren't suffering from failing/failed components or damage from use, so steps need to be taken to identify problems and repair whatever is possible.
Reply 33 of 35, by Demolition-Man
It has been repaired. Two capacitors and the RAM were changed.
Three games have caused problems so far. Super Street Fighter 2 after the 1.5 patch, which enables MIDI. The MIDI doesn't work properly in the game either. And slightly suspicious, two Lucas Arts games. TIE Fighter CD, and Dark Forces. The music works there but then notes hang in other MIDI applications until the PC is restarted.
Reply 34 of 35, by fillosaurus
Not so certain about the Ram limit since I played FF VII (and VIII) 16 years ago on my then new Athlon x2 with 1 then 2 GB and I had no problems at all. Tested music with Soundblaster Live! for GM, and AOpen Yamaha 754 PCI for GM and DS-XG.
XG sounds better, compared to it GM sounds flatter even with a bigger custom soundfont, not those which came with Live! driver CD.
Reply 35 of 35, by Joseph_Joestar
fillosaurus wrote on 2024-06-12, 15:27:
It might be platform specific. For whatever reason, the aforementioned error message went away after I limited the RAM to 512 MB via MSCONFIG. I could reliably reproduce that multiple times, but again, it could be specific to my system and OS setup.
I'm not sure if a SBLive can automatically load the special soundfonts that ship with FF7. These contain stuff like custom instruments and the vocals for One Winged Angel. I haven't tested this thoroughly though, but I vaguely recall it not working correctly on a SBLive out of the box. In contrast, everything works as it should on an AWE64 Gold, with vocals and all.
file.php?id=98613&mode=view
That said, I too prefer FF7's XG music, which you get by either using a Yamaha YMF 7x4 card or an external Yamaha XG module. It doesn't have the vocals in One Winged Angel, but it sounds better in every other way, at least to my ears.
My retro stuff
