Voodoo 2 and artifacts
First post, by iraito
It was working perfectly on another system, I moved it and now I get this.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
Reply 1 of 6, by DrAnthony
That screams memory issues. It would be odd for it go from fully functional to this sort of state just getting unseated and moved to a new system but it is almost 30 year old hardware so anything can happen.
Reply 2 of 6, by zyzzle
Looks like some of the VRAM got fried during the move...
Reply 3 of 6, by rasz_pl
not fried, brittle solder under one of the pins let go, typical 3dfx issue
Reply 4 of 6, by iraito
Well, after checking any broken connection with a microscope and seeing no issue, i installed the latest official driver from 3dfx for the V2, now everything works.
Why do i always solve things in the weirdest way?
Reply 5 of 6, by Shadzilla
Which driver were you using before that was causing issues?
