WP32 McCake : MT32 compatible waveblaster board
Reply 420 of 470, by Snoozer
Wouter wrote on 2023-03-10, 02:41:
I had this same problem on a Pentium MMX 233 with an Aztech 2320 based card. I checked the MIDI IN pin with an oscilloscope, and it had full amplitude high frequency noise on it. My hypothesis was that the level converter on the WP32 could not handle the high capacitance on the MIDI IN line of the sound card, so I added an AC terminator (series capacitor and resistor) between MIDI IN and GND. Now it works perfectly.
I'm having a similar problem with an Aztech 2316 based card. It would be appreciated if you could provide a little more detail regarding the AC terminator modification. What value capacitor and resistor did you use? Did you solder these to the sound card at the back of the wavetable header, or on the McCake itself?
Reply 421 of 470, by megatron-uk
Can anyone let me know what is the expected behaviour of the various LED parts on the rear of the McCake board?
I believe I have an issue with getting enough power to my board, as I get no output at all - but only the first two green LED's are lit; I believe these are '5v' and '3.3v DAC' ... the others all remain unlit ('3.3v Pi', etc).
I don't currently have the FDD power supply in place (lack of free FDD connectors from my Pico PSU supply) - would this be typical behaviour in that situation?
https://www.target-earth.net
Reply 422 of 470, by keropi
you need to connect the FDD power else the pi will not get power
the wavetable header alone is not made to power a pi4 - even if it's a CM4 running at low freq
Reply 423 of 470, by megatron-uk
That explains it then 😀
Reply 424 of 470, by Wouter
Snoozer wrote on 2024-03-17, 12:01:
I used a 100 ohm resistor and a 10nF ceramic capacitor, soldered on the McCake itself between MIDI in (bottom row, second pin from the right) and any ground (top row):
MIDI IN --- 100R --- 10nF --- GND.
I assume these values may have to change depending on the board, and in general I found it quite finicky, so would not consider this anything else than a bodge. It works for me though.
Reply 425 of 470, by badmojo
I have a couple of questions, apologies if these have been asked before:
- is the LED required for the board to work? Or can that be left off?
- will any variant of the CM4 work OK? There is a 'Lite' version available for example, would that work?
Thanks!
Reply 426 of 470, by dreamblaster
badmojo wrote on 2024-06-09, 07:32:
I have a couple of questions, apologies if these have been asked before: […]
Thanks!
- the OLED display ? not necessarily needed - so far i always soldered this on the card
- works only with CM4 Lite versions (boots from micro sd card)
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 427 of 470, by badmojo
Thanks for the reply 👍
Just considering my options here - I was ready to go with the MP32L but I tested out 2 different gameport-to-midi cables I have here and the joystick passthrough didn't work on either of them, so now I'm thinking of going internal.
Reply 428 of 470, by crusher
Do anybody know of buyable front panels aside from the Serdaco ones?
I saw nice ones on Google picture search. But often these were hobby projects and not for sell.
//Edit:
This one looks awesome!
It even has a slot for the microSD 😀
Unfortunalety I have no twitter / X account and cannot look inside his account page.
You can find it here:
https://x.com/jihoda
Reply 431 of 470, by dreamblaster
McCake review by Phils computerlab : https://youtu.be/KRRM1D98yOY
Reply 432 of 470, by Kouwes
I saw Phil’s review and immediately bought one, with a 3.5” panel!
Already have an X2 and X2GS but I like the MT-32 sound on this one.
Not sure which system I’m going to use though…486DX33, DX2-66 or 386DX40. Probably the 486/33 I guess.
Reply 433 of 470, by appiah4
Kouwes wrote on 2024-09-02, 10:05:
The 386DX is actually the best fit in the lot.
Reply 434 of 470, by B24Fox
Sorry to veer off for a bit here; but does anyone know if the WP32 McCake still has issues in the game "LOOM" in MT32 mode ??
Reply 435 of 470, by Kouwes
I actually started up that game just yesterday, sound seemed ok to me. I didn’t pay much attention though, but I‘ll check it out again after work.
Reply 436 of 470, by B24Fox
Kouwes wrote on 2024-09-20, 04:34:
Here is a comparison during the "OVERTURE" part : https://youtu.be/Yo0I6IF8iDc?si=chIb7s1IJPe-3pF0&t=712
An instrument seems to be misinterpreted as a laser pistol or something... 😕
Reply 437 of 470, by SScorpio
B24Fox wrote on 2024-09-20, 11:08:
In the comments there's the question of MT-32 versus CM-32 ROMs. And root42 responds they are MT-32 ROMs. But I still think that sounds like one of the added CM-32 sound effects.
I'm not sure if there's a follow up video or something, but that specific version of the game needs to be helped with MUNT itself. It's possible something is wrong with the game. Or there's a bug that's somehow gone unseen. It really doesn't seem like something that would be WP32 McCake specific.
Reply 438 of 470, by Tandy1000TL
Is there any way that Nuked SC55/emusc could be added to the McCake? That would be absolutely awesome to emulate both MT32 and SC55 in a native type of way, rather than utilising sound banks for the SC.
Tandy 1000TL, 486DX4-100, IBM Aptiva K6-233, P2, P3, P4, C2D
MP32L, MT32, SC55-MKii, SC-8820, Integra-7, MotifRackES, MU80, MU500, etc.
SB 1.0, Snark Barker, SB1.5, SB Pro, SB16, Awe64, Adlib Clone, PAS16, etc.
X2GS, S2, MCCake, Orpheus, BlasterBoard
Reply 439 of 470, by SScorpio
Tandy1000TL wrote on 2024-11-09, 08:12:
Maybe, but the McCake just runs MT32 Pi. Nuked SC55 would need to be added to that and Dale the author of MT32 Pi had issues with the license Nuked was released under and said he wouldn't support it. I'm not sure if anything had changed in that regard.
It's always possible someone else could do it instead. But MT32 Pi runs bare metal on the Pi. It's not just a Linux distro with certain packages installed. It also depends on what the final processing requirements end up being. Hopefully the CM4 Lite will have enough juice to run it.
