First post, by ariqu
I really don't know why this is happening, but for some reason, I cannot get Cubic Player to play anything in Fedora 8. Using the last version of Open Cubic Player and Cubic Player 1.7, the screen where you would see the notes and everything comes up, but does nothing and shows no loaded samples.Cubic Player 1.6 shows the notes flying by at full speed with no sound. All of my games work with no difference from when they're run from DOSBox in Windows.
The soundcard autodetection text shows it finding the SB16 I specified in dosbox.conf as well as any other SB I set it to, but does not do anything. This is happening under the normal core. Under the dynamic core, OCP simply causes DOSBox to crash with a segmentation fault. The other 2 remain the same.
All 3 work just fine in Windows XP on the same computer, so it's got me wondering just what would be doing this.
Reply 1 of 8, by wd
Rank DOSBox Author
DOSBox Author
Does it happen for OCP as well? Think that's the latest available version.
Maybe try different sound devices, like GUS.
Reply 2 of 8, by leileilol
CP 1.6 works for me. Try strictly specifying Sound Blaster in the parameters (it might be trying to use Gravis Ultrasound)
Debian's fucked
Reply 3 of 8, by ariqu
I finally found it. Apparently, CP/OCP does not like how DOSBox provides its Tandy sound support, or Tandy in general - I dunno, I don't have running hardware to check.
Anyway, to all who use Cubic Player, Tandy sound needs to be disabled to use Cubic Player.
Reply 4 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
tandy sound is disabled by default by dosbox.
Water flows down the stream
Reply 5 of 8, by ariqu
Yeah, I enabled it for some Tandy sound testing and never disabled it.
Reply 6 of 8, by wd
Rank DOSBox Author
DOSBox Author
And you didn't read the TROUBLESHOOTING section of the readme.
Reply 7 of 8, by ariqu
I just looked at the readme. It does not mention anything about Tandy sound emulation causing issues with any software, nor have I read any documentation anywhere stating Cubic Player has issues with Tandy hardware. In fact, I have read about past experiences of users on Tandy machines running CP/OCP. So, it did not immediately occur to me that there was an issue with Tandy sound emulation and the method by which (O)CP address the sound hardware.
I fail to see how the readme would have helped in this situation.
Reply 8 of 8, by Qbix
Rank DOSBox Author
DOSBox Author
i think the troubleshooting section tells you that you should use a default configuration file for dosbox.
Running a certain game closes DOSBox, crashes with some message or hangs:
- see if it works with a default DOSBox installation
(unmodified configuration file)
