I don't think they ever got enough yield out of 250nm K6-3 for them to be functional if modded, if there are any around. Seen a lot of decapped K6-2s, have several, all K6-2 shaped, [] , no squarer ones. When AMD wanted slower industrial/embedded processors in 2005, they did a run of 500Mhz morgan durons, and the pluses were in that niche also prior to that. 2001 to 2005 AMD had a lot more profitable product to be fabbing, unless they schlepped the 250nm plant to another site, I don't think there was opportunity in there for later 250nm K6-3 cores and nobbled k6-2s to happen, and it didn't happen in 1999, or examples would have been noted among the first wave of K6-2 decappers. When 250nm was done, it seems to have been done, with a lot of the plant recycled into the 180nm that did the pluses and then was too busy doing durons etc.
