Best soundcard for my Pentium III 3dfx build ?
First post, by laios67
Just finished the first phase of building my midi tower with Pentium III and voodoo 3 , this motherborad has no onboard option for sound and I'll plug one of the many soundblasters I have in boxes , drawers , old mobos etc
I found all these :
CT2980 ISA card
CT1600 Soundblaster Pro 2 ISA card
CT4170 Sound Blaster Vibra 16XV ISA card
CT4810 Soundblaster PCI card
SB0100 Soundblaster Live!5.1 PCI card
SB1070 Soundblaster 5.1 PCI card
So what I put now ? what do you sugest ? output will be simple stereo and backward compatibility would be desirable .
thanks in advance for any help
Pentium III 1ghz Coppermine 750mb SBLive! Voodoo 3 3000 AGP
Compaq Deskpro Pentium III 933 EN 500mb Geforce4MX 440 AGP
Pentium 4 1.8ghz Northwood 500mb Voodoo 3 3500 AGP
Pentium 4 1.7 ghz Northwood 1gb Voodoo3 3000 AGP
Reply 2 of 23, by SScorpio
What do you plan on running? For Windows use the Live! 5.1, but if you also plan to do any DOS gaming, I'd also use the CT4170 if you are targeting end of era DOS games that could do 640x480, while having OK Adlib, but still far superior to the what the Live outputs for DOS music.
Reply 3 of 23, by Thandor
If you take the SBLive! you’re better off with the VxD drivers. The WDM are slower and can cause stutter (at least it doesn’t work well with my Pentium III 3dfx Win98 build 😉).
thandor.net - hardware
And the rest of us would be carousing the aisles, stuffing baloney.
Reply 4 of 23, by laios67
ok thanks for help , I'm interested mostly on windows 98 glide games (thats why I put the voodoo afterall) and perhaps some Dos titles , so I put the live! .
Reply 5 of 23, by Linoleum
Totally agree with the SB0100 recommendation! I have that card installed in my P3 (TNT2) and P4 (Voodoo3) and it's really an impressive card emulation and MIDI wise...
Just make sure you follow the guide: Guide: Installing Windows 9x and DOS drivers on Sound Blaster Live! cards (version 3.1)
P3 866, V3, SB Audigy 2
P2 300, TNT, V2, Audigy 2 ZS
P233 MMX, Mystique 220, V1, AWE64
P100, S3 Virge GX, AWE64, WavetablePi & PicoGus
Prolinea 4/50, ET4000, SB 16, WavetablePi
486DX2 66, CL-GD5424, SB 32, SC55
SC386SX 25, TVGA8900, Audician32+
Reply 6 of 23, by Boomer
I would go CT1600 Soundblaster Pro 2 ISA card for MSDOS gaming and SB0100 live for windows gaming. 💪
Reply 7 of 23, by ciornyi
Thandor wrote on 2024-03-29, 17:41:
Doesn't vxd cut eax compatibility.
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8600/4096mb/SB X-fi/HD6850
Reply 8 of 23, by Joseph_Joestar
ciornyi wrote on 2024-03-30, 06:36:
You've got it backwards. It's WDM drivers which have issues with EAX under Win9x.
When using the official SB0100 installation CD, the installer asks whether you want to use VxD or WDM drivers. On that screen, Creative actually states that VxD drivers should be used for gaming while WDM drivers are more suitable for professional tasks like music creation. It's the same for their Audigy cards.
Reply 9 of 23, by laios67
may I ask what is your configuration winth P4 and Voodoo3 ?
Reply 10 of 23, by Linoleum
laios67 wrote on 2024-03-30, 22:11:
The key is to have an early P4... It has a PC Chips M925 motherboard with universal AGP. I wanted to make sure my V3 wouldn't be bottlenecked... Since that V3 is probably running at full capacity, I have a 50mm fan on top of the heatsink, and a 120mm intake fan blowing directly towards the card.
Reply 11 of 23, by kingcake
IBM MWAVE
Reply 12 of 23, by laios67
very interesting indeed , until now what I have read is that P4 is simply not compatible even if it has a universal agp and even if it has 3.3v support , what is the motherboard model exactly ?
Reply 13 of 23, by Linoleum
laios67 wrote on 2024-04-01, 19:03:
Not true! It's a micro-ATX coupled with a 1.8Ghz P4: https://theretroweb.com/motherboards/s/pcchips-m925lr
So it's very small and packs a punch! I get 3dMark scores pretty close to the record score I could find in old forums without overclocking anything on that thing...
Reply 14 of 23, by laios67
You have installed Windows 98 ? I found in my stuff one P4 1.8 mobo , It doesn't support AGP 3.3v but you gave me idea , to use it with some nice AGP card plus Voodoo 2 PCI .
Reply 15 of 23, by Linoleum
laios67 wrote on 2024-04-04, 10:39:
Yes, installed Windows 98 flawlessly. Lucky you for being a owner of a V2! You sure won't be bottlenecking that V2!
I had every single version of Voodoos that came out, but got rid of them... 🙁
Reply 16 of 23, by laios67
I just finished the mobo and it seems to fit windows 98 pretty well . Northwood P4 1.8 1gb+ Geforce fx5600 128bit - 256mb . Haven't install any game yet and still have to plug the V2 in pci . I think it is my first succefull install of windows 98 on a P4 . The speedy ones simply does not want them From the install rarely go beyond second boot .
Reply 17 of 23, by Linoleum
laios67 wrote on 2024-04-05, 12:28:
I just finished the mobo and it seems to fit windows 98 pretty well . Northwood P4 1.8 1gb+ Geforce fx5600 128bit - 256mb . Haven't install any game yet and still have to plug the V2 in pci . I think it is my first succefull install of windows 98 on a P4 . The speedy ones simply does not want them From the istall rarely go beyond second boot .
Perfect rig for the NOLF series! What sound card did you take for this build?
Reply 18 of 23, by laios67
At the moment is with the onboard AC97. Drivers for windows 98 work ok . I can put one of the remaining PCI or look for another Live! . These can easily found.
Reply 19 of 23, by laios67
Today I searched every P4 and motherboard I had , mostly one step before the recycle bin . And was lucky , never noticed before , I found something interesting . GA -8SMML , micro atx , with support of agp 1x 2x 4x and 3.3v . Checked with intel i740 2x card . I also found a second P4 1.8 Northwood , so I can make a system like yours . I still have a V3 3500 , so I can use it in this build
