First post, by zuldan
I thought I'd try my luck and ask if anyone has seen this Multi IO card (ADD2 DW729) before. All the interfaces are working except for the second IDE interface (IDE1). I'm guessing it's just a jumper configuration issue but I can't find any info on this card.
Any hints or tips would be greatly appreciated.
1.51 MiB
1.85 MiB
Reply 2 of 8, by zuldan
douglar wrote on 2024-04-07, 03:17:
Wow amazing. Had no idea a tool for this card existed. Thank you!
I managed to get a second hard drive working on the second IDE port, however it wont work with CDROMs. I'm going to try the CDROM in the first IDE port and see if that works.
Really hope it's not a case of the card only working with hard drives.
Reply 3 of 8, by Horun
Nice ! Am curious which VLB motherboard you are using.
Reply 4 of 8, by zuldan
Horun wrote on 2024-04-07, 04:27:
This is the one https://theretroweb.com/motherboards/s/dataex … ert-exp3406-1.1
Currently has a 486 DX2 66 in it and Tseng ET4000 VLB 1MB
Reply 5 of 8, by zuldan
So it appears the motherboard does not support CDROMs, therefore the Multi IO card will not support CDROMs. Next best option is to get a sound card with a CDROM interface.
Reply 7 of 8, by zuldan
wierd_w wrote on 2024-04-07, 08:52:
Or finagle some way to get xt-ide installed?
Found this in a box. Do you think a CDROM would work with it?
1.73 MiB
