First post, by kahuna
Hello Vogons!
In short, I'm not seeing a great performance improvement on 3DMark2000 comparing a single Voodoo2 versus two Voodoo2 in SLI.
My system is a VIA C3 Nehemiah 1.2GHz, 392MB RAM, Geforce3 as primary display.
The Voodoo2 are a matched pair of Creative CT6670 with 12MB each.
With this CPU there are no K6/3dnow optimizations, nor Pentium III ones. It's just "D3D Software T&L optimizations".
The drivers I'm using are the latest official ones: 3dfx Voodoo2 V3.02.02
Tested one single Voodoo2 card, the score was 1861 at 800x600, 16bit, Triple FB.
Tested the other Voodoo2 card putting it in place of the first one, so only this Voodoo2 was present. The score was 1859 at 800x600, 16bit, Triple FB.
Get both Voodoo2 cards in the system, connected the SLI bridge, the display properties on the 3dfx tab indicate that the Scanline interleave is detected. FBI revision 4, FB memory 8MB, two TMUs, TMU revision 4, Total Texture Memory: 16MB.
Now 3DMark2000 allows me to select 1024x768x16. In any case I tested on 800x600, 16bit, Triple FB; to match what I did with the single cards.
The score bumps up to 2013.
Not sure what to expect, but it seems kind of a small improvement for all the trouble...
I guess it's the test I'm running that is not very representative? Perhaps those Software T&L optimizations are hurting?
In 1024x768x16 I've got 1955 points
Finally, I tried with the "FastVoodoo2-v4.6" drivers, the score in SLI at 800x600x16 was 1611.
Thoughts?
Thanks!
Be free!
Reply 1 of 17, by kahuna
I just tried with Unreal Tournament. Is it possible that 3Dmark2000 is not disabling v-sync or something like that?
The thing is in UT I get 60 fps on the first 1-on-1 death match when I set the config to 60Hz, and 72-75fps when I move the slider to 75Hz.
Be free!
Reply 2 of 17, by Shadzilla
I don't know how the VIA chip compares to a Coppermine P3, but I get approx. 2480 points in 3DMark2000 with a 700MHz Coppermine and V2 SLI, and that's with the default benchmark settings (1024x768x16 etc.). Same 3Dfx drivers as you, no tweaks.
Reply 3 of 17, by leileilol
kahuna wrote on 2024-04-08, 18:36:
That wouldn't matter. There's not a single Voodoo in the world with hardware T&L.
Another thing to keep in mind about SLI is that the texture thrashing penalties are worse, so for some later games, SLI would bring slower results. That's what the SLinfluencers don't tell you 😀
Reply 4 of 17, by kahuna
My thinking on the Software T&L is that it can hurt performance because it's one more thing that the CPU needs to do. i.e. "software render vs. hardware render" type of thing.
With a Coppermine there is some sort of optimization, or at least it looks that way as in 3DMark they have "using Intel PentiumIII optimizations" (whatever that means, idk!)
leileilol wrote on 2024-04-08, 20:55:
Haha, SLInfluencers, that's a good one!
I just want to make sure it's worth to keep both Voodoo2 in SLI. Anyone can argue "well, it doesn't hurt". Yeah, but there are not so many PCI slots for everything... wondering if it will be a better use (yet another) sound card 😁
Be free!
Reply 5 of 17, by Trashbytes
kahuna wrote on 2024-04-08, 21:54:
My thinking on the Software T&L is that it can hurt performance because it's one more thing that the CPU needs to do. i.e. "soft […]
SLI lets you run in 1024x768 instead of 800x600, that's worth keeping SLI, SLI is also about on par with a V3 2000 performance wise so that's another plus.
Besides you really only need two sounds cards, an Aureal A3D one and a Creative EAX one ...any more than two is pointless unless the third is an ISA one with intelligent MPU401 and Wavetable support.
Reply 6 of 17, by kahuna
I continued my testing. Using the tweaker folder of the FastVoodoo2 drivers, I installed the Overclock panel.
Then overclocked to 100MHz both Glide and Direct3D. The result on 3DMark2000 is now 2044 at 800x600x16. Without OC it was 2013.
The next test was to disable "Don't sync buffer swaps to monitor refresh rate for Glide" (same for Direct3D). That gave me the same result on 3DMark2000.
With that "vSync" disabled and still running at 100MHz, I played Unreal Tournament, just the first death match.
Average FPS at 800x600x16: 85fps
Average FPS at 1024x768x16: 65fps
That is with "world texture detail" and "skin detail" in high. Not bad!
Interestingly enough, I didn't see any screen tearing.
Next up is Need for Speed Porsche. Configuration as follows:
800x600x16 (I cannot go any further)
Medium for 'car detail' and 'car lighting'
Very High for 'world rendering quality' and 'view distance'
Headlights on 'vertex', lens flare 'on', sky rendering normal.
With all of that when there are other cars in the screen (8 total), I get around 30 fps quite solid.
If I'm alone on the road, it goes up to 45 fps or so. That is a quick race on the first circuit, just at the beginning.
Overclocking the CPU from 1.2GHz to 1.4GHz helps as well 😎
2296 marks in 3DMark2000 at 800x600x16.
NFS Porsche is also more playable, getting 10-15fps extra thanks to that CPU overclock.
Now the not so good part (at least on my system), DOS Glide games.
I'm running them on 'real' DOS mode, I'm not launching them from Windows 98 or anything like that.
Tested Carmageddon and Tomb Raider Gold. Both didn't want to start at all, until I lowered the FSB speed and disabled branch prediction on the CPU.
Problem is that for instance in Tomb Raider, it drops below the locked 30fps when you reach the bridges area.
I tested many other speed configuration options, it seems when it's going too fast it just doesn't want to start the game at all; if I lower the speed, it's just not fast enough... quite sad 🙁
I played Tomb Raider using the 3dfx patch for Voodoo2, I will try it again with the 'voodoo rush' one. It also works btw, I just didn't test it that far.
Be free!
Reply 7 of 17, by kahuna
More testing, if anyone is interested, going back to a single Voodoo2 12MB card.
All of the following has been tested at 800x600x16.
3DMark2000: 1918 marks with the Voodoo2 overclocked to 100MHz
Unreal Tournament: First death match, played until I win: 52fps average at 100MHz
Unreal Tournament: First death match, played until I win: 45fps average at stock speed
Overclocking the CPU doesn't have any effect on the performance in Unreal Tournament.
NFS Porsche: With other 7 cars on the track I get 25 fps. Just alone in the circuit, it bumps up to 40 fps. All of that with the Voodoo2 OC to 100MHz.
If I overclock the CPU, I can see 27fps or so when there are other cars. No gain when it's just me.
So, besides being able to play up to 1024x768, it's clear that there is an actual performance gain in games with two Voodoo 2 in SLI compared to just one, that's a relief.
Still working on the DOS Glide games situation...
Be free!
Reply 8 of 17, by kahuna
Hello again,
Going back to the DOS Glide games situation...
Besides Tomb Raider, is there any other DOS game that can show an FPS counter?
I'd like to have a number on the screen to test with different speed configurations of the FSB and CPU, so I can r really compare them instead of just "feeling it"
Thanks!
Be free!
Reply 9 of 17, by DarthSun
P4 should be given to SLI at 4145MHz 104/104 and rushing.
Voodoo2SLI/3DMark2000 new world record
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 10 of 17, by kahuna
DarthSun wrote on 2024-04-11, 17:58:
Pretty cool DarthSun.
I also have a Preshot around, but getting over 3000 marks is not the goal of this build. I'm just trying to build a nice all-rounder machine, decent or pretty good for a bunch of different uses 😉
By the way, that 4GHz P4 must be quite warm, I had mine OC'd to 3.6GHz and yeah, I couldn't complain much about its performance!
Be free!
Reply 11 of 17, by DarthSun
kahuna wrote on 2024-04-11, 20:04:
Pretty cool DarthSun. I also have a Preshot around, but getting over 3000 marks is not the goal of this build. I'm just trying t […]
Is burdened around 50 degrees Celsius, not warming, Delid CPU+ThermalTake.
The attachment prescott_off.jpg is no longer available
The attachment p4p800_tt.jpg is no longer available
But anyway, I set it to 3.8GHz for use, just the big clock to the summit. 3.8 This specimen is almost cold, as if it were cool, a selection of D0.
Reply 12 of 17, by kahuna
Nice!
Just in case my previous question got buried, anyone knows of any DOS Glide games that have an FPS counter? (besides Tomb Raider).
Thx.
Be free!
Reply 13 of 17, by DarthSun
kahuna wrote on 2024-04-11, 22:57:
Nice!
Thx.
I don't know like that, I used to try old time to Voodoo during DOS , I used to Glide under rather Windows.
Reply 14 of 17, by kahuna
I have been playing around a bit with DOS Glide games.
Reducing the FSB to 75MHz and leaving the multiplier at 9x, gives me the performance of a roughly K6-2 system. I believe it should be ok for DOS Glide games.
If I try to go higher, I get in a situation where I get a black screen when I enter the game 🙁
Be free!
Reply 15 of 17, by biessea
kahuna wrote on 2024-04-10, 05:33:
More testing, if anyone is interested, going back to a single Voodoo2 12MB card. All of the following has been tested at 800x600 […]
Hey mate, please help me if you can.
I just installed NFS Porsche and wanted to play in my beautiful Voodoo 2 SLI system, with a Tualatin 1,4ghz.
But when I run 3dsetup and I select Voodoo2 card, in game I can only set the 800x600 max resolution, like the games cannot see the SLI that I have in my system. (And it works correctly for sure).
Any hint? Patch? Some registry editing?
Computer lover since 1992.
Love retro-computing, retro-gaming, high-end systems and all about computer-tech.
Love beer, too.
Reply 16 of 17, by chinny22
Should work without modification? Does NFS3 or 4 which is based on the same engine allow higher then 800x600?
I apply the "Enhanced version" patch more for some of the in game tweaks then any technical reason but maybe it'll work?
https://www.nfsplanet.com/en/news/1679
That said unlike the earlier games Porsche doesn't really benefit from glide, so personally I play in D3D mode in 1024x768 now
Reply 17 of 17, by subhuman@xgtx
Lei, have you ever tried Monster Truck Madness 2 with Double Buffering/Triple Buffering turned on?
Usually, besides what the name says, the game will increase in-game quality of all trucks and scenery textures.
It may just be me, but the texture trashing is terrible with an SLI setup with this option turned on.
Talk about sudden slideshow-like framerates while looking at 5 trucks on screen, even with a 1.4ghz P3 1400-s.
Bear in mind I usually post to the forums using my old systems.
