First post, by clintonoddfellow
Good Morning!
I'm currently trying to revive a P5A-B Super Socket 7 motherboard I've come across.
So far, according to my POST card, the board doesn't make it to POST. Looks like it's being held in reset for some reason.
Although it behaves the same with or without CPU, I've gone through and validated all jumper settings against what is correct for a K6-2 350.
Since the board supports both AT and ATX supplies, I have tested it with both. ATX soft power works, but the board remains held in reset.
I've replaced the battery with a fresh one was well, in case that was causing any gremlins, but no change in behavior.
No obvious physical damage. Board is warped a bit along the "front" edge, but no worse than I've seen in a lot of AT boards.
I'm looking for suggestions on where to look next -- Hopefully I can use this as a learning experience as well!
Thank you!
