First post, by psaez
Hi
I have this setup:
- Tualatin 1400S
- DFI CA64-TC
- 512 RAM
- SD to IDE adapter (or sata to IDE adapter)
I have a problem, after installing VIA 4in1 Chipset Driver downloaded from https://theretroweb.com/motherboards/s/dfi-ca64-tc#driver it request a reboot. After restarting, it detects USB port and tries to install drivers, then, it crashes and windows 95 install gets corrupted, damaging SHELL32.DLL and preventing windows to start, simply showing the error that the file is corrupted and that windows can't start and must be reinstalled.
Any ideas about how to solve this?
EDIT: well guys, I tryed installing first xusbsupp as some guys has recommended here... fresh clean W95 OSR 2.1 install, then, xusbsupp, then, the drivers I told you for this motherboard: VIA 4in1 Chipset Driver downloaded from https://theretroweb.com/motherboards/s/dfi-ca64-tc#driver
After installing the via drivers, it request for a reboot, and then, similar problem, now It can proceed installing the USB part, but after that, again similar errors, and again stuck with broken W95 install:
