Pcmcia adapter help needed
First post, by George Razvan
Hi all,
I have a NEC Versa 2535,without CD-ROM. OS is Win 95 OSR 2,all drivers installed. For transfering files I have used a serial connection, but it's too much hassle, since I need to setup another pc from storage. So I have bought an NEC PCMCIA to SD Adapter. I use a 1 GB Kingston card, but it doesn't show up in My Computer. Do I need separate drivers for this adapter? How do I make it work? I have no previous experience with pcmcia so please forgive my ignorance on this subject.
Tks
Pentium 75 MHz ,Intel Advanced /ML ,64 MB RAM ,Matrox Millennium II,160 GB 7200 RPM
Pentium Pro 200 MHz, Intel VS440FX,32 MB RAM, Elsa Gloria Synergy,40 GB 7200 RPM
Dual Pentium III 650 MHz,512 MB RAM,3 x 4.5 GB SCSI Quantum Viking II 7200 RPM
Reply 1 of 22, by Proto-Schlock
I've only used PCMCIA CF adapters. Those are pretty much plug and play. Does the PCMCIA adapter show up in the device manager? Have you tried running add/remove hardware from the control panel?
Reply 2 of 22, by wierd_w
Are the drivers installed for the PCMCIA bus controller?
more to the point, are you sure they are the CORRECT ones?
Reply 3 of 22, by George Razvan
wierd_w wrote on 2024-04-21, 08:54:
Yes the drivers are installed. No exclamation mark in device manager.
Reply 4 of 22, by wierd_w
This is not always indicative that the CORRECT ones are loaded, sadly.
I remember facing this issue *A LOT* back in the day, especially with regard to Texas Instruments PCMCIA and Opti PCMCIA controllers.
Have you verified function with some other PCMCIA card? Card services properly start and stop, eg, modems?
Reply 5 of 22, by Bondi
I think apart from PCMCIA drivers Win95 needs drivers to support SD cards. Not sure they exist, however.
Just like it needs IDE device drivers to work with CF card(in a PCMCIA adapter).
Did your adapter come with own drivers?
PCMCIA Sound Cards chart
archive.org: PCMCIA software, manuals, drivers
Reply 6 of 22, by George Razvan
wierd_w wrote on 2024-04-21, 09:08:
I only have a wifi pcmcia adapter. I'll check if something happens when I insert it, even if windows 95 doesn't know anything about wifi.
Reply 7 of 22, by George Razvan
Bondi wrote on 2024-04-21, 09:20:
No, no drivers. But since it is an adapter it should be transparent to the os that on the other side od the pcmcia bus is a cf, sd, etc. Information about pcmcia to sd adapters Are scarce on the net, but I have noticed that they are advertised as driver free.
Reply 8 of 22, by George Razvan
Proto-Schlock wrote on 2024-04-21, 08:13:
No, it does not show. Yup, tried add hardware wizzard, nothing is found. I consider getting an pcmcia cf adapter. But since it is an adapter, it should be transparent to the os that it is an sd or cf at the other end.
Reply 9 of 22, by Bondi
George Razvan wrote on 2024-04-21, 09:32:
What's the brand of your adapter? Does it officially state support of Win9x?
I think it really depends on the adapter if it's transparent to the OS. If it has internal conversion from SD to IDE, then it can be seen by an older OS. But it may also rely on external drivers or newer OS, which has built-in support for SD cards.
Reply 10 of 22, by George Razvan
Bondi wrote on 2024-04-21, 10:13:
NEC. I have tried with my only other adapter that I have, which is an asus wifi adapter. Nothing happens. I haven't found any information about this laptop, so I don't know anything about it's pcmcia brigde. It is identified as a Omega micro pci to pcmicia bridge. Seems to work in device manager.
Reply 11 of 22, by wierd_w
If cards dont make a "BooDoop!!" sound when inserted, then the bridge driver is NOT working correctly.
Reply 12 of 22, by wierd_w
VCFED saves the day with a link to NEC FTP archive via Archive.org, that should work with this machine.
https://archive.org/details/ftp.necam.com
Double check that the CORRECT PCMCIA bridge driver is loaded, then be sure that cards properly announce when inserted or removed.
Reply 13 of 22, by George Razvan
wierd_w wrote on 2024-04-21, 10:38:
No sound.
Reply 14 of 22, by George Razvan
wierd_w wrote on 2024-04-21, 10:42:
Awesome. Tks, get back with the results.
Reply 15 of 22, by George Razvan
Still does not work. Reinstalled the driver. There is only one driver for this laptop, so I have no other ideas.
Reply 16 of 22, by Ryccardo
George Razvan wrote on 2024-04-21, 09:35:
It depends - many, probably most, do simulate the most common applicable disk (so presumably a CF for PCMCIA - though you still get their choice of memory mapped/port mapped/IDE compatible modes in that case), but others are native/original-ish interfaces needing drivers (probably more common for the minority and more proprietary cards like SM, 🤣, MS)
In modern Linux this would appear as sd* versus mmcblk* 😀
But yeah, in either case the card would appear as a PCMCIA accessory!
Reply 17 of 22, by lolo799
Can you show your Nec SD adapter?
You can find a trial version of Cardware 7.0 at tssc.de, give it a try.
Reply 18 of 22, by George Razvan
lolo799 wrote on 2024-04-22, 20:06:
This is the adapter. I don't have any experience with pcmcia. So besides the drivers I need... What? What are Windows 95 pc card services?
Reply 19 of 22, by wierd_w
The 'pc card services' driver is a kind of ... 'control interface' for the cards in question.
A software interface that lets windows talk to cards to get info on what resources they need, allows windows to start and stop cards being enabled, inform when a card has been inserted or removed, etc.
Win9x has some generic ones, but they dont always work right, even if they load right (or claim to, anyway...)
In your case, when the card is inserted, 'something' should show up in the device manager tree when the card is inserted, and once the card starts, you should hear an audio signal that the card started: a 'boo-doop!' Sound, with a mid-tone as the boo and a higher tone as the doop. (When a card is stopped, its a midtone followed by a lower tone.)
If no tones are heard, and nothing shows up in device manager, it usually means the pcmcia card services driver is not working correctly.
