First post, by rain
- Member
Hi i try to taking image of win98 . but when trying making image to hdd is says :
"Dump file is on drive being dumped "
Are you trying to save the image to the hard drive which you are trying to image ?
Because that is what it sounds like that the line "Dump file is on drive being dumped " means.
Do not ask Why !
weedeewee wrote on 2024-04-21, 15:00:Are you trying to save the image to the hard drive which you are trying to image ?
No im created d: drive instead c and trying make on it
if it's the same physical drive then it's the same physical drive
