Reply 500 of 505, by Sphere478
- l33t++
Re: IDT Winchip 2A PR266 a.k.a "Weirdo"
Anyone have a functioning setup live at the moment for a test?
Sphere478 wrote on 2024-02-27, 13:35:Re: IDT Winchip 2A PR266 a.k.a "Weirdo"
I don't know what you want to test, but both the rig from the linked thread and one with a modded Tillamook on a MVP3 mb with cache are running here.
JustJulião wrote on 2024-02-28, 18:51:Sphere478 wrote on 2024-02-27, 13:35:Re: IDT Winchip 2A PR266 a.k.a "Weirdo"
Was curious about the response from the chip when intel bf2 was pulled high. Changing bf0, bf1.
From what I recall, intel bf2 basically defaults to pull down when floating.
And when bf2 is pulled down bf0,1 provide 133-233 mhz options.
But when intel bf2 is pulled high the chip always is at 266 no matter what bf0,1 are set to.
If someone can verify that. Not with my setup atm.
Hi guys.
Does anyone know if the Tillamook 266mhz will work on a Asus p5a-b ?
Had a guy that made the mods on the cpu for me but no luck getting it to post.
Show picture of mods are, update, bios, have you verified the voltage is correct
