First post, by appiah4
- l33t++
I've always wanted to build a Socket 8 system. I've been holding off for a Dual Socket build with my matching 200MHz 512K CPUs, but a motherboard for that has not crossed my path in the last five years and I am starting to lose hope that it ever will. As a result, I decided to YOLO the build and go for a single socket 200MHz 256K one.
The problem is, I have no idea what to do with it. Part of me wants to install Warp 4.5 and be done. Part of me wants to go NT4.0 instead. Part of me wants to go 2000 Pro (which was my initial goal with a dual socket system) but I'm not sure it's really that good a fit with just one core.
I'm also not sure about what hardware to stick in it. I suppose a Socket 8 system would be pretty half assed without some kind of SCSI hard drive setup, so there's that. I'm not sure how much RAM I want to stick in there. It will be a PCI/ISA system, so there is also the video/sound card choices to make.
I guess ultimately all these depend on what I want to do with the system, but honestly I don't know. None of the OSs above are great for gaming, and to be fair neither is Socket 8. I suppose I could set it up as a workstation to install some old engineering software I used to work on back in the late 90s, like I-DEAS.. I'm open to suggestions on that regard as well.
TLDR; I don't know what to do with my Socket 8 build and what to put in/on it, so let me know what your Socket 8 systems are like 😀
