First post, by Sephiroth, The Great
What is W26361-W10-Z2-02-36 W26361-W10-X-02 motherboard? I can't find retroweb page for it.
Reply 2 of 4, by PC Hoarder Patrol
Sephiroth, The Great wrote on 2024-04-27, 10:13:
Believe its this one - https://theretroweb.com/motherboards/s/siemen … tem-board-d1107
Reply 4 of 4, by PC Hoarder Patrol
Sephiroth, The Great wrote on 2024-04-27, 11:20:
Thanks. That is the one. And if my has only 2 RAM slots soldered then that means only 512MB RAM max? What would be best CPU compatible with this motherboard?
Probably depends on board revision...unofficially good chance with mid-range coppermines. Someone even managed a 1.4 GHz Tualatin Celeron on a slotket Re: Powerleap slot-1 adapter
Official SNI list is attached
supported_cpu_bxzx.pdf
12.03 KiB
11 downloads
