First post, by Marco
Dear all,
I noticed that since using the xt ide bios following thing occurs:
- during boot up hdd detection, my WDC is like spinning on and off 3x
- same happens when shutting down w95
- same happens when testing dma speed (yes strange example)
- besides that operation is fully normal
- this only applies to my WDC 80gb hdd, this won’t happen on a 420mb hdd, 300gb maxtor
Do you have any clue? I have the slight feeling that these events won’t prolong lifetime of that hdd 😉
Thanks
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 1 of 9, by douglar
I have not seen that. Perhaps the landing zone detected incorrectly?
Reply 2 of 9, by Marco
Ok I will try the revise values in the original bios for that drive. Thx for the first hint
Reply 3 of 9, by Marco
I put following numbers for lzone:
- cylinders
- cylinders-1
- 0
Unfortunately no change in behavior. Strange thing
Reply 4 of 9, by Yoghoo
Seems like a problem I had as well. See here for a solution I received: https://forum.vcfed.org/index.php?threads/xti … 34#post-1305261.
I needed to make a custom XTIDE build and remove MODULE_POWER_MANAGEMENT. I also removed MODULE_SERIAL, MODULE_SERIAL_FLOPPY and MODULE_WIN9X_CMOS_HACK as I didn't need it for my 386DX. After that the problem was resolved and it booted a hell of a lot faster as well.
Reply 5 of 9, by maxtherabbit
Yoghoo wrote on 2024-04-28, 21:13:
This is bang on. There is a known issue with MODULE_POWER_MANAGEMENT. Build it without that module and you will be fine.
Seems few people notice this since everyone is using solid state BS these days...
Reply 6 of 9, by douglar
maxtherabbit wrote on 2024-04-28, 21:54:
BS means "Blazingly-fast Storage" no doubt!
Reply 7 of 9, by Marco
Wow great. That’s it. Thanks a lot. I mean I would assume that a 80gb drive is well aware of PM but your symptoms are identical. Damn that I am not owner of my eprom burner anymore 🙁((
Reply 8 of 9, by maxtherabbit
Marco wrote on 2024-04-29, 05:39:
It's a bug in the XUB. The drive being aware of power management is what makes it susceptible to the bug.
Reply 9 of 9, by Marco
Ok understood. Also found the instruction for custom builds - just have to organize a burner again.
If anyone has an idea of how to deactivate the win95 shut down hdd-handling (power mgmt function / or parking) -> very welcome. Could maybe be a a registry hack but I couldn’t google anything
