First post, by Dombie
I got this laptop at a thrift store for about 6 dollars (Canadian). Aside from a few broken keys, it works pretty well!
Its original OS was Windows 98, but it had XP when I got it, so I did a fresh install of Win98. I got the display drivers to work just fine, but I've been struggling to get it to play audio. Sound was working in XP, so the speakers or sound card can't be broken.
Here are some links to drivers that I tried:
https://archive.org/details/evo-n600c-restore (Says it's for 98)
https://www.philscomputerlab.com/ess-es1988-allegro-1.html (Says it's for 9x)
https://www.catalog.update.microsoft.com/Sear … x?q=ESS+allegro (Only says it supports 2000 or XP)
https://support.hp.com/us-en/drivers/swdetail … SG_I11057-32198 (Only says it supports XP)
If anyone has managed to get sound to work in 98 on this model (or at least a similar one), can you please tell me how?
If you need more information, feel free to ask questions.
EDIT: Just noticed that there is a category specifically for sound. Sorry for posting this under "General Old Hardware". Is it possible for an admin to maybe move this to "Sound"?
Reply 1 of 7, by Horun
Ok There is a driver for Win98SE (not orig Win98) for the EVO N600c. It never had Win98 original from what I can see, so if that is what you installed you may never get the audio to work...
Drivers see here: http://web.archive.org/web/20030820211609/htt … ate/4_2044.html
audio takes you here: http://web.archive.org/web/20030817071845/htt … load/11013.html
gives you Softpac # 17163 and 18965.
so for 17163 go here: https://ftp.zx.net.nz/pub/archive/ftp.hp.com/ … 500/sp17163.txt
and here: https://ftp.zx.net.nz/pub/archive/ftp.hp.com/ … 500/sp17163.exe
Hope that helps. Would just post the files but better you see where they came from..... 😁
Reply 2 of 7, by Dombie
Pretty sure this is SE.
Thanks for links. I'll check them out later.
Reply 3 of 7, by Dombie
Sorry for the late response. I tried sp18965 and 17163, but neither of them worked. However, once a chord sound manged to play when I was installing the driver, but after restarting, sound was nowhere to be heard.
I would like to note that sometimes when I try to install the driver, it prompts to put in the Windows 98 Second Edition CD to look for files like swmidi.sys, dmusic.sys, etc. etc., but when I put in my CD, it doesn't find the files. Maybe I should try a different iso?
Reply 5 of 7, by Horun
kingcake wrote on 2024-05-16, 21:48:
For Win98: 4.10.2222A is SE.
You can try the official ESS drivers: https://www.zx.net.nz/mirror/www.esstech.com/ … pp/drivers.html
Did you get the ISO off Archive dot org? Those are a mess to find a good one. Winworld is better for that.
Agree ! The stuff on WW is more reliable unless you know the archive org poster.
IIRC people that started WW are old school Usenet junkies and is how they got most of their stuff, from reliable posters back in the day 😀
added: swmidi.sys and dmusic.sys (and .dll's) are in the Driver12.cab file of 98SE full....
Reply 6 of 7, by Dombie
The CD I used I believe was burnt a few years back by my dad so I'm not 100% sure where the ISO is from, but REMOVED is our go-to place for old Winodws ISOs these days. I have a feeling the one I used has an OEM version so I might try to see if it can find the files from a retail one.
Reply 7 of 7, by Dombie
I copied over the files from a full retail ISO, reinstalled Windows 98, and sound seems to be working fine now! I guess there was just something wrong with the CD.
