First post, by mtest001
Hi all,
I have an annoying issue with my P225MMX build. Whenever I try to quit Windows 98 SE and restart in MS-DOS mode via the shutdown dialogue box, the computer sort of freezes: the task bar disappears, the desktop remains on screen, I can move the mouse pointer but not click on anything, and the keyboard becomes unresponsive.
3.78 KiB
1.61 MiB
I tried to apply the "shutdown patch" but it does not change anything.
Any idea?
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB Live! + Sound Canvas SC-55ST = unlimited joy !
Reply 1 of 4, by mtest001
So it turns out that my problem has something to do with the SB Live! drivers I have installed... If I manually kill the process "Devldr16" then the computer reboots in MS-DOS mode right away.
I need to find out which version of the driver works on my machine.
Reply 2 of 4, by Blzut3
I haven't experienced this issue exactly, but for whatever it's worth a lot of times I've found that "Restart in MS-DOS mode" produces an seemingly unclean environment. On several of my systems I'd find games that simply freeze the system on startup. However, if instead I have Windows present a boot menu at start up and I just boot directly to DOS everything works fine. Plus the config can be tuned for each mode more easily. Given that I don't recall as many problems in the past I'm sure it's a case where finding the right driver older versions would help, but in my opinion it's worth considering if the "Restart in MS-DOS mode" option is overrated.
Reply 3 of 4, by mtest001
Yes I agree that's the way to go. I just would like to make it work as it should, i.e. not freezing when try to switch to MS-DOS from the start menu...
Reply 4 of 4, by mtest001
Ok just to confirm that after changing the SB Live drivers the problem is gone, I can now reboot in MS-DOS mode...
