First post, by AppleSauce
 - Oldbie
So I've beaten all the Tex Murphy games up to this one and I want to give overseer a go.
Now initially when I first set it up a day or two ago I had the game set to use my Creative DXr2 card but honestly the card gives a pretty dark and washed out video output, I could get a dxr3 but I'd need to splice up up a hard to get cable so I decided to go the software route since I've got a 800mhz pentium 3 running win98SE which I figured that might be enough grunt.
I installed Xing and Elecard player and updated the game to 1.04 but now the game won't start it wont maximise the tab. Since I've got a crt that supports 2 inputs I switched over to the other card on a whim and got a display much to my suprise.
The other card is a matrox mystique and it complained about not having enough video memory which makes sense given its a 4mb card and not a 32mb one so it looked like it might be trying to use that card over my main one?
I'm not sure if its a conflict related issue , its really odd though since the 1.0 stock install used my 256 DDR just fine even with the drx2 disabled it wont play movies but can at least reach the main menu, but with the patch either something borked or it just defaults to pci instead of agp. I've tried disabling the card in device manager , but maybe I need to disable it in the bios is that even possible?
If anyone has any suggestions let me know since I'm pretty keen on playing it even though it is technically a remake of mean streets which I've already beat.
