First post, by JaKSLaP
Hi
I recently installed VSC in Windows 98 and got it working with Doom95. My Question is has anyone been able to get in working running dos games like duke3d in the inbuilt MSDOS environment? If so what settings do u use to get it working?
Reply 1 of 1, by stanwebber
yes, vdmsound will work in win98 for this. i recommend you comment out (disable) all soundblaster and adlib emulation in the config file and run with just mpu-401.
if your pc is fast enough, dosbox is another solution
