First post, by Shinra
- Newbie
Hi, recently started using GliDOS to play one of my favourite games Redguard. For the past few days I've been enjoying playing through the game after the installation and set up went very smoothly. The logo was annoying but I intended to buy the unlock code today until I encountered a big problem. Just to make this clear, absolutely nothing on my system has changed to my knowledge between now and last night when I was last playing happily.
I execute GliDOS and since my "Adjust" setting are all fine I click Start Game (as usual) and the DOS command appears and then the warning about DOS cannot access the Hard Disk which I click Ignore to. All normal up to now. But instead of "Glide Server" opening and the game running absolutely nothing happens. The process ends and I can retry as much as I please to no effect.
Here's exactly what I see, after I click ignore nothing happens.
http://img229.imageshack.us/img229/2006/glidosib3.jpg
Naturally I checked all the settings and they're the same as what worked for me up till now. The disc is in and in working order (as it always autoruns when inserted) so I can only imagine that GliDOS would be the problem. I'm left confused because I haven't changed anything at all, my files are all the same, drivers are up to date and unchanged since Redgaurd and GliDOS was installed. I reinstalled GliDOS but that changed nothing.
Hope you can help me, I want to get back to playing 😢
Windows XP Pro SP2 (Fully updated)
3 GHZ Intel P4 Processor
1GB DDR2 RAM
Nvidia 7600 GS (512MB)
Creative Soundblaster Audigy
