First post, by radzio222
I got a problem with my CT-3910. Till it works as AWE32, Sb16 or OPL everything is fine.
But when I turn on AWEUTIL /EM (no matter GM or MT32) when it will try to play a midi it crashes a system. I tired both 330h and 300h -same effect.
Does anyone has similar problem?
Reply 1 of 3, by Gmlb256
Hello.
Are you running protected mode games?
If so, AWEUTIL's MPU-401 emulation won't work with these out of the box. At least there is DOS32AWE which can be used as a workaround for games using the DOS/4GW extender.
Another workaround is to run them within Windows 95/98 if you have it installed on the computer. The emulation is much better there, and with the AWE Control Panel, SF2 SoundFonts can be used.
Reply 2 of 3, by radzio222
So more details. I'm using Dos 6.22. It is not only about Dos 4/GW games. In general even in the old games when I start AWEUTIL when game try to start it crashes. Both General Midi and MT-32
Reply 3 of 3, by Gmlb256
Seems that the motherboard where the AWE32 is installed couldn't handle NMIs as AWEUTIL relies on it for the emulation to work.
Edit: Which version of AWEUTIL do you have?
