First post, by Cursed Derp
Heyyyo,
I've been trying for a little while now to get Daggerfall working on my Windows 98SE pc. I put the Steam version on a cd and installed it from thr cd drive. Everything went fine until I tried to run it. The game said that I didn't have the cd in the drive, even though I had my Steam cd with all the necessary files in the drive. I also tried running the GOG offline installer via KernelEx from a USB drive. The game installed but had the same problem occurred when I tried to run it from dagger.exe. DOSBOX is not an option because it runs way too slow on the pc.
Thank you!
I am as smooth as a gravy train with flaming biscuit wheels.
Reply 1 of 19, by Shagittarius
After copying the entire CD to your computer you need to set the cd path in the Z.CFG file. Where it says "pathcd". Set that to the arena2 directory.
for example my config is:
pathcd d:\bethesda\dagger\arena2\
or alternately point that path to your actual CDROM.
Reply 2 of 19, by Cursed Derp
I reinstalled. I set the size to "huge" and when it was done I copies the entire cd to a folder in the installed Daggerfall directory. I then changed the pathcd in the z.cfg file to point to the folder. The problem still occurred. I like the idea though and I think I can work with it. If it helps the drive I'm installing the game to is d. My cd drive is e.
Reply 3 of 19, by Cursed Derp
This is my z.cfg file after editing and the folder that I copied the cd to.
Reply 4 of 19, by Shagittarius
That doesn't look right. Did you copy the Arena2 folder on the CDrom to D:\dagger\DFCD\? If you did that is the only way that would work. You need to point to the arena2 directory, or its contents directly.
Looking at your screenshot it looks like the correct pathcd might be "D:\DAGGER\DFCD\DAGGER\ARENA2\"
or if you want to point it to your CDrom:
"X:\DAGGER\ARENA2\" where X is the letter of your CDROM drive.
Reply 5 of 19, by wierd_w
If he is trying to play it on bare metal, he needs to make sure that the burned CD has the correct volume label as well.
Reply 6 of 19, by Cursed Derp
What would the correct label be?
Reply 7 of 19, by wierd_w
Give me a bit-- I am pulling from steam again. 😀
the dosbox script that launches it, contains a directive that creates a fake cdrom out of the folder, with the volume label specified. As soon as I get it pulled again, I will tell you.
Reply 8 of 19, by Cursed Derp
Thank ye!
Reply 9 of 19, by Shagittarius
One other thing I forgot you have to launch it specifying the Z.CFG.
Make a .BAT file that specifies:
FALL.EXE Z.CFG
and then launch the game using the BAT file you made.
Reply 10 of 19, by Cursed Derp
THANK YE SO MUCH!!! THE BATCH FILE WORKED PERFECTLY! THANK ALL OF YE FOR YOUR HELP AND EFFORT!
Reply 11 of 19, by wierd_w
the dosbox version contains this directive:
mount D: ..\DF\DFCD -t cdrom -label Daggerfall
The volume label for the burned media needs to be "Daggerfall"
I experienced this issue when setting up UnityDF some time back, which is why I remembered. I just did not remember what the proper volume label needs to be.
Reply 12 of 19, by Cursed Derp
Thanks, I might make a proper Daggerfall cd with this label in the future.
Reply 13 of 19, by Cursed Derp
I have a bit of a minor problem. The intro cutscene won't play. Is there a way to make the cutscenes work? Even the death cutscene won't play.
Reply 14 of 19, by Shagittarius
Sounds like its not finding the files it needs in either the path or pathcd directory.
You can try to copy the files from the cd and make sure that path commands are pointed in the right place.
OR
Because I'm using the free version from Bethesda and you are using the gog version there might be differences. If you download the bethesda version from here: https://elderscrolls.bethesda.net/en/daggerfall
then the way I have told you and the way you have it set up will play all the videos, this is how it works on my machine.
EDIT: Just realized Bethesda now links to the STEAM install. They use to have a standalone package you could use. I still bet they work the same and you just need to make sure the right files are in the directories you are pointing to. Mine runs entirely off the HDD with no need for a CD.
EDIT2: Make sure any sub-directories that exist on the CD were copied over as well.
Reply 15 of 19, by Cursed Derp
I'm using the Steam version. Where are the cutscene files?
Reply 16 of 19, by Shagittarius
Everything in mine is in the arena2 directory.
Here is my directory listing, it has 2 sub dirs that I have not listed:
The attachment DIRLIST.TXT is no longer available
I imagine all the .VID files might be what you are looking for.
Reply 17 of 19, by akula65
It is interesting to note that the old free standalone version mentioned by Shagittarius can still be downloaded from the Bethesda server using the direct link provided by squareguy in this thread:
The Elder Scrolls II: Daggerfall
Reply 18 of 19, by Cursed Derp
Thank you! The cutscenes work now. All I had to do was copy the contents of the arena2 folder from the cd and put them in the arena2 folder in the game's install folder. I had to hold the n key so that nothing overwrite the installed stuff.
Reply 19 of 19, by Shagittarius
Cool! Enjoy the game after all that work!
