First post, by cgyed.cgyed
Hello,
I bought a Toshiba satellite 430 2 years ago with a not working FDD. Until the HDD crashed, it was fine...
Now I have a laptop without suitable HDD nor FDD but a probably working CDROM drive (not bootable).
I tried to install dos 6.22 on a CF card with virtual machine but it does not boot on real hardware and I have no mean to make the famous "fdisk /mbr".
So, I "call" for a solution that may solve the problem. I already tried to fix the fdd without success. I also try to use a FD emulator (openflops w1d) without more success.
A way could be to send my CF Card + IDE adaptor to a "very close hardware" owner who may make me the CF bootable with DOS 6.22.
Another posibilty may be to clone a compact flash from a owner of toshiba satellite pro with CF card drive.
Is someone has a possibility to do this, or to propose any other solution...
Thanks !
