First post, by amontre
Recently acquired an Acer 333s, its 386sx , 12mb ram without HDD. Installed 500mb HDD and manage to boot using floppy to MS-DOS 6.22 , but it failed to create save partition. Using FDISK, I can see the physical drive, manage to create partition, make it active. But once I reboot, the partition disappeared.
I have tried :
- Replaced the HDD with 128mb CF IDE, c/h/s : 992/8/32
- Tried using EZ-Drive but it failed to create partition
- identify IDE using ideinfo.exe (attached image) which revealed error reading the IDE (both HDD and CF)
Is this the sign of failing board ?
The attachment IMG_4181 2.jpg is no longer available
#1 NEC Pentium 133 | 64mb RAM | 40gb HDD | s3 Virge DX | Voodoo 2 | SB AWE64 Gold
#2 NEC 486DX2 66 | 16mb RAM | 40gb HDD | SB AWE64 Gold
#3 Acer 386 SX 33 | 8mb RAM | 20gb HDD | PicoMEM + Adlib
# Amiga 1200 | MSX2+ | Roland MT-32 | SC 55MkII | YAMAHA MU80
Reply 1 of 12, by wierd_w
There is VERY CLEARLY incorrect geometry being reported.
What kind of CF card are you using? It may not be properly supporting old CHS modes.
Reply 2 of 12, by amontre
wierd_w wrote on 2024-06-06, 07:32:
It’s a Kingston 8gb ( https://www.amazon.co.uk/Kingston-CF-8 ... B001NXDB4A)
I did clear (set it to NONE) the CHS in bios and boot with a disk and run ideinfo again with the similar error.
Reply 3 of 12, by wierd_w
I am going to go out on a limb, and ask you to aggressively test your memory, then also suggest moving the IDE controller to a diff slot.
If integrated, try disabling and using a multio card.
The values reported look like either the high or low byte is stuck high, and ghe ident string is gibberish.
So, either
some part of the 1st mb of ram is bad... and data being queried is being stored wrong...
The data bus leads in that isa slot have crud on them, and data coming back from the query is corrupt.
The controller is in some other way hooziered
The IDE device is hooziered.
So, to me, the diagnostic order of elimination, from easiest to hardest fix, is:
Aggressive ram test.
Test with different IDE device
Test of controller in different slot.
Test of different controller.
In that order.
Reply 4 of 12, by kixs
Is the 500MB HDD known to work? I've seen some bad HDDs do that.
What is your actual CF card? One time you say it's 128MB the other time it's 8GB. 8GB is way to big.
Visit my AmiBay items for sale (updated: 2026-03-23). I also take requests 😉
Reply 5 of 12, by amontre
kixs wrote on 2024-06-06, 23:15:
Yes, 500mb hdd are working on my 486DX2
I have both CF card 8gb and 128mb .
Reply 6 of 12, by amontre
wierd_w wrote on 2024-06-06, 18:35:
I am going to go out on a limb, and ask you to aggressively test your memory, then also suggest moving the IDE controller to a d […]
So, either
In that order.
Did a memtest86+ 4.0 last night and it passed all tests. I also tried different IDE HDD, 500 MB (working HDD that I use in my 486dx2) and ideinfo.exe also output the same error.
Next is to test different controllers which I currently do not have and will be ordering.
Since I'm ordering, I'm thinking to order lo-tech XT-CF (https://texelec.com/product/lo-tech-xt-cf-lite-rev-2/) or may be going Picomem (https://texelec.com/product/picomem/?highlight=picomem) route.
Reply 7 of 12, by Deunan
amontre wrote on 2024-06-06, 02:41:
The geometry should be 992/8/32, and that's 0x03E0/0x0008/0x0020 in hexadecimal. What you have there on the screen is 23520/22536/22560, which is 0x5BE0/0x5808/0x5820. Notice anything interesting?
If we subtract 0x5800 from each value we get correct results. In fact it's even easier than this, we need to mask bits rather than subtract, a simple logical AND will suffice. In other words some of the bits in the upper byte are stuck at 1, but not all. It's not a simple issue of the upper part of the 16-bit ISA slot not working at all. It does work but it's glitched somehow.
Try different slot - in fact try all of them, because these are daisy-chained but you don't know in what order (it can be more of a T connection than a simple chain as well). Make sure the IDE card is clean, try a different one perhaps.
Also check your BIOS settings, perhaps you've set some very aggresive ISA clock divider?
Reply 8 of 12, by amontre
Deunan wrote on 2024-06-07, 13:31:
The geometry should be 992/8/32, and that's 0x03E0/0x0008/0x0020 in hexadecimal. What you have there on the screen is 23520/225 […]
Yes you are correct 992/8/32 is the CHS I got when connect it on other computer. The mother board has only 1 IDE hdd .
I did try different IDE with the same results on ideinfo.exe
The attachment IMG_4229.jpeg is no longer available
Reply 9 of 12, by Deunan
amontre wrote on 2024-06-07, 15:26:
Ah, so it's a mobo with built-in IDE controller. In that case it's quite possible there is a problem with signal connection to that IDE connector. The glitching bits are 11, 12 and 14, That would be pins 10, 12 and 16 on the connector.
First check if the pins of the connector are not corroded or very dirty. Probably not so the next step would be to check if the mobo doesn't have a scratch somewhere that cut these 3 signals. The chip that provides HDC and FDC functions is that Acer M5105 that's also on the photo. Check if the pins I mentioned are connected to some of the pins of this chip. If there is no connection you need to look for mobo damage. If there is a connection... well, the chip might be damaged.
Reply 10 of 12, by amontre
Deunan wrote on 2024-06-07, 21:29:
If i add multi io card or something like Lo-tech XT-CF-lite rev.2 , i can bypass using the onboard IDE right ?
Reply 11 of 12, by Deunan
Probably not. Unless there is a jumper on the mobo to disable the built-in IDE, which I doubt. Also that card you mentioned (Lo-tech XT-CF-lite rev.2) is 8-bit only and most likely uses XT, not AT, port for the IDE channel. So it will be slow at best, might not work properly at all in AT system.
What you need is multi-I/O card that can be jumpered to secondary IDE channel, but using normal AT port addresses. And then you'll need XTIDE ROM extension with that as well because the mobo BIOS surely won't be looking for secondary IDE.
With this combo you can leave current on-board IDE as-is, just not connected to anything, and XTIDE can be configured to look for HDDs on the second channel. That would in effect be a bypass and it would not require the existing IDE to be disabled. The problem with this setup is you'd need two extra ISA cards (the I/O one and a network card to be a carrier for XTIDE ROM) and you are already limited with the number of free slots. And there might be some other issues, like which chip is now going to be the floppy controller - most likely it'll need to be the mobo one (since it can't be disabled I bet) and you'd have to configure the extra I/O card accordingly.
All in all it would still be best to try and fix the on-board IDE channel, if possible.
Reply 12 of 12, by amontre
I have solved this by booting XUB on XT-CF
