Socket A: Nvidia vs Via - battle of the platforms!
Reply 340 of 863, by nd22
BIOS screen: version 9R is used as it provides the highest performance. Temperatures are very good for a 60W CPU. Athlon XP is recognized correctly and not as unknown CPU! Voltages are also good despite using a 20 years old Enermax!
Reply 341 of 863, by nd22
BiOS settings are quite particular on this board; I will try to go over the main ones that increase or decrease performance:
SOFT MENU III options
1. fast cpu command decode
2. enhance chip performance
3. force 4-way interleave
4. enable dram 4k-page mode
Each of them provides a very small performance boost and I let them enabled! Although the gains are nothing to write home about every little bit helps KT133A as the chipset is very memory bandwidth limited!
Reply 342 of 863, by nd22
Advanced chipset features page:
Unlike earlier board where I found compatible memory modules that let me select the highest performance options this is not the case with KT7A-raid!
1. DRAM bank interleave: 4-way option increases performance a little bit
2. Delay DRAM read latch: 1.5ns. This settings actually decreases performance. You can select from several options: AUTO to let the board do its thing; NO DELAY - this is the best performing option!; 0.5/1.0/1.5ns delay. The higher the setting the lower the performance will be. I could not get the system to pass MEMTEST with 3 double sided modules unless I set the delay to 1.5ns!
3. MD driving strength: high - it is required in order to get the system stable with 3 512mb memory modules! Has no bearing on performance.
4. SDRAM cycle length: 3 - this settings also decreases performance! The system is stable with 1 double sided 512mb module if CAS is set to 2, but with 2 does not passes MEMTEST! This setting has the largest hit on performance on KT7A! Unfortunately the results will suffer but I simply could not find 3 modules the would let me set CAS to 2!
Reply 343 of 863, by nd22
The rest of the settings are very simple and require no explanation:
Reply 344 of 863, by nd22
CPU-Z vintage edition has great difficulty in recognizing the processor and the RAM:
Reply 345 of 863, by nd22
However Everest 5.50 has no trouble at all in correctly identifying every single component:
Did anyone ever heard of Tanisys tech? For me it's the first time and the first impression is very good!
Reply 346 of 863, by nd22
Before putting up the results I forgot to mention the monitor: Eizo S2100 with a max resolution of 1600*1200!
Also I have to mention that KT7A took the 7600 GT very nice; there was no error, no BSOD, nothing!
Reply 347 of 863, by nd22
Now the results:
The order will always be:
1. nforce1: NV7-133R + sound storm
2. nforce1: NV7-133R + creative live
3. KT133A: KT7A-raid
4.AMD760: KG7-raid
5. KT266A: KR7A-133R
Reply 348 of 863, by nd22
1. The first benchmark is Code creatures pro based on DirectX 8.
1024*768 resolution, default settings, NO sound:
Reply 349 of 863, by nd22
2. Code creatures pro 1024*768 resolution, default settings, WITH sound:
Reply 350 of 863, by nd22
3. Code Creatures pro 1024*768 max settings, NO sound:
Reply 351 of 863, by nd22
4. Code Creatures pro 1024*768 max settings, sound ON:
Reply 352 of 863, by nd22
5. Code creatures pro 1280*1024 max settings, sound OFF:
Reply 353 of 863, by nd22
6. Code creatures pro 1280*1024 max settings, sound ON:
Reply 354 of 863, by nd22
7. Code creatures pro 1600*1200 max settings, sound OFF:
Reply 355 of 863, by nd22
8. Code creatures pro 1600*1200 max settings, sound ON:
Reply 356 of 863, by nd22
Code creatures pro summary:
NVidia is not off to a good start! Nforce1 is at the bottom of the scores!
KT133A is severely bandwidth limited by the SDRAM - this is to be expected - however it manages to slightly edge out nforce1 by a small lead.
AMD760 and KT266A are at the top with VIA leading by a small margin!
Now onto Aquamark3 - a DirectX9 test!
Reply 357 of 863, by nd22
9. Aquamark3
The order will remain the same:
4.AMD760: KG7-raid
First up is nforce1 at default settings - that is 1024*768, no AA, AF 4X, NO sound and the rest of the options at max:
Sound storm first, Creative live second
Reply 358 of 863, by nd22
Next is KT133A:
Reply 359 of 863, by nd22
Followed by AMD760:
