Demo application crashing.
First post, by rarefluid
Hi people.
I have an old DOS protected mode multimedia-presentation here I wanted to run (http://www.scene.org/file.php?file=/parties/1 … mo/tour_by_.zip). It always crashes at the same point however.
I fired up a debug console, which prints this before dying and killing DOSBox with it:
CPU: Illegal/Unhandled Opcode F
PIC:0 mask FF
PIC:1 mask FF
INT10: Set Video Mode 3
VGA: Blinking 8
PIC:0 mask F8
PIC:1 mask EC
EIP of the crash is 0x000109E4. The EXE is packed somehow though...
DOSBox then crashes with an access violation at adress 0. I tried some experimental 0.72 builds (ytwong) too, but got the same results.
Hope anyone can help or tell me this can/will be fixed some day.
cheers
rarefluid
Reply 1 of 36, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
For me it crashes back to DOS after the credits...
(Yhkwong's build has grown a bit old)
Tries to use the opcode 0f 77 (SSE2 or something?)
1+1=10
Reply 2 of 36, by wd
Rank DOSBox Author
DOSBox Author
Should be some MMX instruction, so bad luck.
Reply 3 of 36, by MiniMax
Rank Moderator
Moderator
I don't see any credits. I *think* I see a green flash or something before it exits back to the DOSBox prompt. Tried various combinations of cores, cycles, ems, xms, ubm, all sound devices set to off/false, cga, tandy, pcjr, vga. Will only run with vga, otherwise complains about having to use UNIVBE.
_________________
Reply 4 of 36, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I used my (dirty) latest CVS build.
1+1=10
Reply 5 of 36, by rarefluid
0F77 seems to be the EMMS instruction, so it definitely uses MMX.
Sorry guys. haven't thought of that.
Are there any plan on adding MMX to DOSBox in the near future?
...find some video captures of old DOS demos here...
Reply 6 of 36, by wd
Rank DOSBox Author
DOSBox Author
Nope, but i didn't check this demo yet, could be they're executing rubbish, too.
Reply 7 of 36, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
A 80386 with MMX? 😀
1+1=10
Reply 8 of 36, by rarefluid
A 80386 with MMX? Happy
🤣. I should write before I think...
I don't really know, because I don't know of a way to show the code being executed before the application crahes...
Reply 9 of 36, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The program itself tells me
1+1=10
Reply 10 of 36, by wd
Rank DOSBox Author
DOSBox Author
Exception6 is unknown opcode, just in case you wondered.
Reply 11 of 36, by rarefluid
but you don't see the instruction opcode getting executed. the exe is packed, so I can't have a look myself with a disassembler..
Reply 12 of 36, by wd
Rank DOSBox Author
DOSBox Author
Get some debugger-enabled build of dosbox, should be easier than
disassembling a packed .exe
Either the intstruction is intentional (nothing you can do besides implementing
some mmx instructions) or it executes rubbish, where you'd have to look
WHY it executes that.
Reply 14 of 36, by rarefluid
I have a debugger build of Yk$%&whateverwongs experimental 0.72 builds. Can you point me to decent documentation about the debugger or tell me how to break program execution or step through the code?
That it crashes DOSBox should be considered a bug though! Executing a bad program shouldn't crash it imo...
Reply 15 of 36, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
DOSBox is not supposed to run your nuclear power plant you know 😉
1+1=10
Reply 16 of 36, by rarefluid
Try Bochs
Does it have a video capture capability?! I couldn't find information about that...
I could use it to check out what opcode it executes though...
The demo, if it uses MMX, fails to check the CPU type. Not good. People did nasty stuff in the past, but MMX wasn't that common back then, so I can't believe they didn't test for that...
Reply 17 of 36, by rarefluid
Though you may be right, this should be a very common problem and already taken care of...
Reply 18 of 36, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
It's probably fixed in latest CVS as it didn't crash for me.
1+1=10
Reply 19 of 36, by wd
Rank DOSBox Author
DOSBox Author
It does NOT crash with 0.72 for me.
A dos game executing mmx stuff while not checking for the processor
type is a common "problem"? DOSBox fully takes care of that in throwing
exception6 which is what a real non-mmx processor does.
