Demo application crashing.
Reply 21 of 36, by rarefluid
A dos game executing mmx stuff while not checking for the processor
type is a common "problem"? DOSBox fully takes care of that in throwing
exception6 which is what a real non-mmx processor does.
I just didn't think DOSBox would crash because of that. But that's maybe just in the ytkwong build. I'm sorry if this is the case. I'll check that and will inform him about it.
They actually use the emms only at one place, making it a nop gets
the demo to work (plays fine up to the end afaict).
Wow! Could you send me the depacked exe? Or did you just patch it while running. I could try it myself If I had information about the debugger (how to step through instructions/dump memory/etc.)
...find some video captures of old DOS demos here...
Reply 22 of 36, by wd
Rank DOSBox Author
DOSBox Author
Official 0.72 release doesn't crash for me, maybe you can doublecheck that.
I've just added the emms instruction as NOP in dosbox, didn't mess around
with the demo executables (maybe there's some pmwunpack or so around
so you could try it).
Can you build dosbox from sources?
Reply 23 of 36, by rarefluid
pmwunpack
Is this the packer? I couldn't find any supicious strings in the EXE. Google gives me absolutely nothing... I guess it is something internally used in the demogroup probably...
Not atm. Did it with 0.65 once, so I guess I could. Do you suggest adding a patch to dump the code segment or similar?
And thanks for helping so much!
Reply 24 of 36, by rarefluid
I will this week when I find time. Promised!
Reply 25 of 36, by wd
Rank DOSBox Author
DOSBox Author
Is this the packer?
The unpacker is pmwunlit, can handle the default pmode/w compression.
Well if you manage to compile the dosbox sources, you can simply add
the emms to behave like a nop.
Reply 26 of 36, by rarefluid
Found it, thanks.
I probably need some experimental stuff from the ykhwong build (vsync, ...). But if you point me to the file/function I need to patch I'll try to do it myself.
Reply 28 of 36, by rarefluid
Thanks a lot. I think I'll be able to work it out now one way or another...
Reply 29 of 36, by `Moe`
rarefluid wrote:
That it crashes DOSBox should be considered a bug though! Executing a bad program shouldn't crash it imo...
Well, it doesn't crash DOSBox. Crashing is something else than "Intentionally aborting". While I'm all with you, nothing ever should crash DOSBox, I think it's fine if the CPU gurus choose to E_Exit("some error message"), which is what you are seeing. An orderly, intentional exit.
Of course, we're all aware that this isn't the most userfriendly thing to do. Maybe some version in the near future will show a more userfriendly message, at least if I find out how to do it in the UI.
Reply 31 of 36, by rarefluid
It crashes the ykhwong 0.72 CVS build. It does NOT crash the offcial 0.72.
I'll report that to ykhwong's site.
This was more about help to run that program than the instruction crashing DOSBox...
Thanks for helping out guys. I decompressed the EXE and will now fire up IDA to fix this baby to make it run in DOSBox 😀
Reply 32 of 36, by rarefluid
I unpacked the application and patched the EMMS instruction to 2 NOPs.
Still, the patched EXE is crashing, and its not the EMMS instruction it is crashing at... It is still the same crash address and still a 06-Exception, there are no suspicious opcodes though.
I'm a bit puzzled here.
Reply 34 of 36, by rarefluid
Another NOP (90h). The original code sequence was "0F7790h" if I'm not mistaken...
Reply 36 of 36, by rarefluid
Thanks. I did it in IDA and I only found one "emms". Seems there are more that IDA somehow can't detect...
