First post, by gamingretro
Hi folks, so Quake runs great on my new P3 build running win98. In restart to DOS mode, though, the computer freezes upon exiting the game -- I get the usual Quake exit screen but no dos command prompt. Hitting enter or escape does nothing. Anyone know of a fix? I've got a sb16 and GeForce 2 mx that work fine. Thanks!
Reply 1 of 4, by dominusprog
Have you tried to change the RAM configurations in BIOS?
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 4, by sledge
Interesting! I've encountered the same problem when running Quake on rather unusual hardware (Vortex86DX board), so I thought it must be some weird incompatibility, but it seems the problem lies somewhere else. Anyway - try it without emm386, worked in my case.
doshaven.eu / high-voltage.cz
Reply 3 of 4, by gamingretro
sledge wrote on 2024-06-10, 11:14:
Interesting! I've encountered the same problem when running Quake on rather unusual hardware (Vortex86DX board), so I just thought it must be some weird incompatibility, but it seems the problem lies somewhere else. Anyway - try it without emm386, worked in my case.
Correct, removing emm386 fixed the freezing issue! But now unfortunately I don't have enough conventional memory (519k) to run some dos games. Any ideas for increasing that without emm386?
Reply 4 of 4, by Gmlb256
gamingretro wrote on 2024-06-11, 00:08:
With UMBPCI, a real mode driver that generates UMB from memory intended as shadow RAM. It depends on the motherboard chipset as it affects cacheability and ISA DMA in the UMB area.
