Reply 27760 of 30585, by zuldan
- Oldbie
iraito wrote on 2024-06-11, 08:03:I'm the the process of priming and sanding, after that I'm gonna finish with a dark gray.
Very cool. Please show another picture with it installed when it’s complete.
Done, I really like the end result.
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
iraito wrote on 2024-06-11, 10:20:Done, I really like the end result.
Very nice. Clever idea!
Ooh so this is what it's for, nice! I don't own any midi module so maybe this is a really stupid question, but what's wrong with putting the smaller sc-55 on top of the mt-32?
konc wrote on 2024-06-11, 11:36:iraito wrote on 2024-06-11, 10:20:Done, I really like the end result.
I imagine it's because the SC-55 is longer (length-wise) than the MT-32. Trying to stack an SC-55 on top of the MT-32, the SC-55 would overhang at the back.
Shponglefan got that right.
I see, it makes sense of course. The sc-55 looks a lot smaller in pictures if you've never handled one.
That's awesome!
I'm just playing around with a Korg AG-10 (Audio Gallery) that arrived last night. It came out around the same time as the SC-55. I think in a lot of ways the SC-55 sounds better, but the AG-10 is no slouch either. I still need to clean it up but it works fine.
EDIT: a picture I grabbed off the net for the curious
I'd say it's more consumer level. And more like the SC-7, the desktop version of the 55 with few displays etc.
appiah4 wrote on 2024-06-11, 08:11:BetaC wrote on 2024-06-10, 22:37:I spent the better part of my day getting things somewhat organized while setting up a new computer space in my family's house. I also attempted to see if I could find an MT-32 hat for my Pi, but it seems that the MISTer has ruined any chances of me looking for non-MISTer versions.
I built this one for myself and it works perfectly: https://github.com/chris-jh/mt32-pi-midi-hat
Serdaco also sells a very nifty one for 3A but works on 3B: https://www.serdashop.com/MP32L
Thanks. Seems like I'm going to have to deal with international shipping if I don't want to get the PCB made myself, 🤣.
I tried to upgrade an Asus AM2 board with nForce chipset to an MSI 785GM-E65 AM3 board so that I could have two 1Gb ethernet ports (one onboard and one on a PCI card), since the nForce only has a 100Mb port. Windows 2000 did not like the other board, however. No matter how much stuff I uninstalled or stripped out of the registry, something kept hanging the service control manager, and then it would spew a nonsense error message "1077 no attempts have been made to start the service" (wtf? I just told you to start it!). In that state, networking was totally broken, and no program that installs its own driver on the fly (eg. CPU-Z) would run.
I eventually gave up on it, but by then I had cloned the HDD to a newer, bigger, and faster one which happens to have similar power consumption rating. The old WD-Green is stamped 0.65A on 5V, and 0.50A on 12V, while the newer WD-Black is stamped 0.68A on 5V, and 0.55A on 12V. The WD-Green also has over 40,000 hours of runtime while the Black is only at 12,000. So I put the newer disk in the original computer with the Asus board. Now a weird thing is happening where Windows wants to run CHKDSK everytime it boots, but it doesn't actually run it because it says it's "not a Windows 2000 disk" 🤣.
I might also drop a faster CPU into the Asus board. Bravedown bilibili downloader started serving 1080x1920 videos again, and now they're using 60fps and HEVC. This is great except that if I want to play portrait format videos on my portrait format monitor, HEVC is too CPU intensive for the Athlon X2 4850e. The problem is that any K10-based CPU I put in is going to run hotter than the K8, especially in a single-power-plane board, because the CPU-NB will start glitching if you lower the voltage too much. And that is bad, because this is a microATX case with a dinky power supply. So I haven't decided yet. I could just re-encode the videos.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
bakemono wrote on 2024-06-12, 12:36:I might also drop a faster CPU into the Asus board. Bravedown bilibili downloader started serving 1080x1920 videos again, and now they're using 60fps and HEVC. This is great except that if I want to play portrait format videos on my portrait format monitor, HEVC is too CPU intensive for the Athlon X2 4850e. The problem is that any K10-based CPU I put in is going to run hotter than the K8, especially in a single-power-plane board, because the CPU-NB will start glitching if you lower the voltage too much. And that is bad, because this is a microATX case with a dinky power supply. So I haven't decided yet. I could just re-encode the videos.
If you can sneak a 1030GT low profile in, you can let that do the HEVC stuffs. Not sure what AMD options there are in graphics, GCN 3 upward has the support, but they kept dragging over Oland cores for teh low power low end, so not sure where the next low power card is that does it....
.. yeah nearly nothing from AMD until near modern.
edit: RX 640 or WX 3200 maybe but they are weirdos, might find one under $50 to screw around with, but they don't do older DX so well as nvidia either.
bakemono wrote on 2024-06-12, 12:36:I eventually gave up on it, but by then I had cloned the HDD to a newer, bigger, and faster one which happens to have similar power consumption rating. The old WD-Green is stamped 0.65A on 5V, and 0.50A on 12V, while the newer WD-Black is stamped 0.68A on 5V, and 0.55A on 12V. The WD-Green also has over 40,000 hours of runtime while the Black is only at 12,000. So I put the newer disk in the original computer with the Asus board. Now a weird thing is happening where Windows wants to run CHKDSK everytime it boots, but it doesn't actually run it because it says it's "not a Windows 2000 disk" 🤣.
Wonder if a scan from within Windows would fix the fact that it is trying to scan at boot?
Repaired a Kensington Mouse-in-a-box serial mouse that hasn't worked in 4 years. 1 25V 10uF capacitor later, she's back to working order. Why is it that they used 85°C rated capacitors on these things, eh?
Also made a couple of Socket 370 Tualatin boards nice and shiny, but the capacitors are an eyesore and will get taken care of once I order capacitors for the boards. That and I cleaned the Apple Macintosh Classic M1420 logic board and RAM expansion board since they were dusty and had some spots I didn't see (under chips, it's hard to see that).
bjwil1991 wrote on 2024-06-13, 01:59:Repaired a Kensington Mouse-in-a-box serial mouse that hasn't worked in 4 years. 1 25V 10uF capacitor later, she's back to working order. Why is it that they used 85°C rated capacitors on these things, eh?
I'm picturing an engineer saying: "Why has the cap in my mouse PCB design been changed from 105C to 85C rated??"
Boss answers: "How hot do your hands get???"
Engineer: 🤦
The nerve of some people. Even my Orion TV1333 has 85°C rated caps and the inside can boil water for crying out loud.
I'm just glad I fixed the mouse after all these years. Almost tossed it out, but I decided to keep it and see if replacing the cap would fix it or not make it work. Got so lucky that I was able to fix the thing. Now, I need to flatten the optical serial mouse pad since it's not flat anymore.
bjwil1991 wrote on 2024-06-13, 03:09:The nerve of some people. Even my Orion TV1333 has 85°C rated caps and the inside can boil water for crying out loud.
Just curious, but what is the significance of this particular mouse?
(Not judging! I actually replaced the left click button on a first generation Logitech Optical Mouse almost 20 years ago because I wanted to keep using it on a second PC... I still have it!)
Pretty sure I have one of these in a sealed box somwhere.
Today, I got a Wyse Cx0 thin client (which doesn't have Windows 9x drivers for its 3D accelerated video or onboard audio), running Windows XP, to very convincingly fake Windows 98SE.
(Sure, there are little things, like Printers, Scheduled Tasks, and Web Folders being missing from My Computer and the Open/Save dialogs are definitely not 9x-original... but it's a very convincing fake. As far as "How immersive is it for someone who knows it's not really Windows 98SE?" goes, I'd say it's less of a problem than how 86box has no option to make floppy drive and hard drive noises.)
EDIT: Found the X-Teq X-Setup Pro option to hide the places sidebar in Open/Save dialogs. They look Win9x original now too.
Here's a screenshot from my HP t5530 running actual Windows 98SE for comparison:
EDIT: Oops. Forgot to set a 24-hour clock on the Windows 98SE one and rename My Network Places on the Windows XP one. Those are now fixed on the actual machines.
The process is basically:
Internet Archive: My Uploads
My Blog: Retrocomputing Resources
My Rose-Coloured-Glasses Builds
I also try to announce retro-relevant stuff on on Mastodon.
Ozzuneoj wrote on 2024-06-13, 04:11:bjwil1991 wrote on 2024-06-13, 03:09:The nerve of some people. Even my Orion TV1333 has 85°C rated caps and the inside can boil water for crying out loud.
It has 3 buttons (second is I believe the left double-click or maybe for scrolling). It's for my 386 desktop so it can have a mouse connected to the KVS box I have.
I recently got this Micronics 386 ISA board from another member because it was dead from battery damage, he had performed repairs but it still wouldn't POST. I believe the board matches this one.
I have tinkered with it a bit, I have tried a different BIOS, reseated many chips and done an assortment of other things. I am able to get POST codes out of it on my diagnostic cards, and some things I have done have gotten the numbers to go higher but I can't really make sense of what it's doing beyond that.
From the speaker I get what seems like 4 short beeps (they blend together) followed by 2 more beeps spaced out evenly.
Anyway, I'm not going to expect anyone to diagnose it for me, but I have discovered a questionable component on the board that I don't have a lot of experience troubleshooting.
I was using my Fluke75 meter in diode test mode (it should beep once in one direction on diodes, with no beep going the other direction), and one of these diodes gives no beep at all. It also seems like it might be cracked around the middle (I can feel it with my fingernail, and through a magnifier it looks cracked), which seems strange. I have marked it with a red arrow.
EDIT: Confirmed, it is totally cracked in half! When I poke and prod the poor thing the ends move independently, so it definitely needs replaced.
I'm clueless about identifying diodes, but I have these on hand that look similar: 1N4148 and 1N4733A
If anyone can help me identify that diode and whether the ones I have on hand will replace it that would be a huge help.
Also, I have checked for continuity and shorts involving the repairs the previous owner made and they seem fine, so I don't believe that is what is preventing the board from booting.
