Reply 20 of 31, by Syntho
cloppy007 wrote on 2024-06-09, 20:19:You're right. I've got 2 similar PCI/ISA post cards and one of them won't work in 5V-only PCI slots (nor ISA...). Have you... […]
- Measured the VRM output? If your board has the VRM slot it will surely have 2-4 jumpers, you can get the CPU voltage from any of those. Otherwise it'll be in one of the leads of the transistor with a heatsink just next to the battery
- Verified the BIOS chip? If you have access to a programmer, try reading the BIOS chip to see if it reads something or garbage.
- Cleaned the cpu and bios sockets with IPA or contact cleaner?
I had an extra bios chip ready to go. Switching it did nothing. I cleaned the CPU socket with non-residue contact cleaner and blew it out with compressed air. I also switched two other CPUs in its place and none of it worked. Just now I checked the solder joints on the back of the motherboard where the transistor is. I don't know which pins are which, but it was giving me 1.5V to 1.6V.
