First post, by AAVVIronAlex
- Newbie
I just got an ATi Radeon 9250 AGP 2X/4X card for my Windows 2000 setup. I installed Windows 2000, but I cannot install the drivers.
I got the drivers from here: https://www.amd.com/en/support/downloads/driv … 250-series.html
I tried installing both the Catalyst Software Suite and the regular driver, both did not work. Firstly there was an error which was something to do with DiretX missing, I got a DirectX version from OldVersion. Then there were two more issues, which came after each other before the program close.
The first error was: inf error video driver not found
The second error was: setup was unable to complete installation try to setup your display adapter with a standard vga driver before running
I tried to uninstall the devices in device manager, I tried booting into safe mode and doing it from there. Does anyone know how I should do this? Theoretically it is supported to have a GPU like the Radeon 9250 on Windows 2000, as it has drivers for it.
What can I do to get these drivers installed?
Thanks a lot.
